Question about Kenwood KAC-9152D Car Audio Amplifier
Need help kenwood kac-9152d
Yes i have had my amp about a year and it was working great but the other day i was checking my wires to make sure they were tight and my screwdriver touched the side of the amp when i was checking my main power wire and my amp cut off and it did not blow any fuses or anything like that and i took it apart and checked inside to see if anything was burt and i didnt see anything wrong and now i have to put a gound on the body of the amp plus the main ground to get it to work can you tell me what i may have missed that could be the problem
  • 47 Answers
This has been answered on a previous post!
Click Here to be redirected
Upfront Audio :)
Posted on Apr 23, 2009
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood kac-929 amp is melting my ground cable help
That amp needs 4 gauge power and ground wire minimum. Too small of wire is just like using too small of a water main to a house....it's just not gonna work out
Jun 05, 2010 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
I need help
Most of the time if the red light is on the amp is no blown but some times it does this cause the subs are hooked up in the wrong way. If the amp is only 2ohm stable and you hook the subs up to it at 1 ohm than the amp will not work so I would check this frist.
Oct 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Power on amp switch off when base is turned up
A: make sure that speakers size and watts.B: Type of speakers is used for base. C: Make sure the current (Amps)of the battery and your amplifier. D: Check audio from source and decrease the level of base. Thanks.
Feb 09, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D problem
It sounds to me like you may have burnt a trace off of the bottom of the circuit board inside the amplifier. If you know how take the amplifier apart and look carefully at the traces. To be clear the traces are the lines on the bottom of the circuit board not the component side. Look carefully they can sometimes be hard to spot. If you find one solder a jumper wire across the two points. If you take the amplifier apart take care in treatment of the output transisors along the sides.
Jan 17, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
69 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
