Question about Mitsubishi WL-82913 82" Rear Projection HDTV
I have a WL82913, recently the lamp was replaced but the red color appears brown, after resetting all the colors it is the same.
SOURCE:
vortash
  • 431 Answers
SOURCE: Lamp Issue with Mitsubishi WD-62725
Hi I am Vortash it sounds as if the actual fault is in your ballast circuit this is the circuit that fires up the arc on the lamp and sends the signal to the main board that the lamp is running , if this is faulty no signal is received by the board and the lamp light comes on when this happens there is usually still sound but not always as sometimes the problem affects the power supply also .. this is a job for a trained engineer as voltages at the ballast are sometimes in excess of 25000 volts at first arc that then settles to a lower voltage to run ... regards Vortash
Posted on May 30, 2009
Slinteriors
  • 8617 Answers
SOURCE: tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Posted on Jun 10, 2009
Bat1956
  • 585 Answers
SOURCE: Mitsubushi VS-5043 Rear Projection,,, Replaced 3
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Posted on Nov 10, 2009
  • 143 Answers
SOURCE: In need of a replacement lamp for a Mitsubishi
bulbtogo $169,00 plus s+h
Posted on Dec 04, 2010
hardrocko
  • 1476 Answers
SOURCE: replaced burnout lamp. now lamp flashes amber
ses120169,
It sounds like when the lamp went it may have damaged the ballast. I have a tip at
http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen
and another here
http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv
which will be helpful determining the problem and getting the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 01, 2011
Why is my Sony 3lcd projector not showing the color red?
I hope its on warranty because that sounds like a circuit board problem. Was the replaced lamp the original specification?
-GWOOD
Jul 14, 2014 | Office Equipment & Supplies
Why is my Sony 3lcd projector not displaying the color red?
you didn't provide age of your projector, but it likely is about dead, and not worth fixing again.
Mar 08, 2018 | Office Equipment & Supplies
I have a Samsung DLP HLR5067 modeel tv, recently we have replaced the lamp, ballast and color wheel. The color is ok but when we watch dark (color)movies the black and browns look shadowed and irdescent. ...
You probhably have the wrong color wheel. There are several different ones and its imparitive that you replace it with the correct one. If you search here theres someone else that had the same issue and when they put thier old noisy color wheel back in the problem went away.
Nov 15, 2010 | Televison & Video
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Panasonic PT-52LCX16 DLP TV color problem
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Apr 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
No red it display
Its not the lamp. Test other inputs. Check cable for bent pin.
Nov 21, 2007 | Sharp XR-10X Multimedia Projector
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
