Question about LG Dishwashers
Looks like mold on glasses - LG Dishwashers
    Problem Solver:
  • 4 Answers
Try cleaning the whole inside very well and then try using a different dish washing soap
Posted on Apr 18, 2009
Mold and Mildew
several products can be used --- white vinegar --- bleach---exit mould ---
Jun 22, 2013 | Limeaway Lime Calcium And Rust Remover 28...
Benchmark fiberglass front door molding around oval leaded glass has cracked and has caused the whole oval to slip down. Can the molding be replaced? Can provide picture if needed.
Steel entry oval ring holding in glass has been knocked out by large dog. The glass is still in tact but the oval molding is damaged. Can just the oval molding be ordered and do you have installers to perform the work? Thanks!
May 20, 2011 | Garden
Do & Discover Crystal Growing kit came with 2 spanish ONLY directions...How do we get the right dirsctions so my son can Do & Discover?!
I patiently used Google Translate and got this. The instructions may not be in perfect English, but it's good enough to understand. Good luck :)
GROWING CRYSTALS
1.
experiments require a large measurement cup (at least 32fl oz / 0.9 1) Heat resistant glass mix the powder and boiling water. The vessel measures must be glass or plastic Resistant to heat. You also need a medium saucepan (at least 32 fl oz / 0, 9 1) to boil water. Separate carefully cut molds, as pictured. Make sure to leave a border around each mold. Also remove sharp edges from the edges with scissors.
2.
Use a large glass measure (at least 32 fl oz / 0, 9 1) (not included) to measure 0.68 liters of water and pour into a medium-size saucepan. Heat the pan until the water boils.
3.
Open the bag of potassium sulfate 10 (diamond frosting) with chemical crystal growth and pour the contents into the glass of measures.
4.
Pour boiling water in medium saucepan shot glass with the contents of the bag 10.
5.
Stir the mixture with the big stick until all the grains are completely dissolved chemicals. NOTE: Let the mixture cool for 5 minutes after the grains have dissolved.
6.
placed 2 rocks on the bottom base of the 5-sized plastic molds "C" of growth. These basement rocks should rise only about 3 / 4 "(2cm) from the bottom of mold growth.
7.
Pour the chemical solution / water shot glass molds in size 5 "C" for crystal growth. Make sure to fill each mold in the same way, leave an inch (8mm) of space between the liquid and the edge.
8.
After removing the bottle cap coloring dye, carefully cut with scissors (not included) the tip of the boat. Individual drops slowly drops of dye into the mold of crystal growth. see diagram following Mercedes to mix colors. Once you add the dye mixture solution with the small mixing stick. NOTE: Do not add dye to the mold of a glass. transparent crystals are better for the electronic.
9.
Place the mold of crystal growth in a place where not disturbed by movements or changes in temperature. crystals begin to grow in a matter of hours. let the crystals grow for three or four days without disturbing them. You can then remove the crystals from the solution. For best results, wash the crystals abundantly in the sink to remove excess dye and place on a newspaper or paper towel for a day to dry.
10.
if the mass of rock crystal and the base have been a square shape due to the structure of the mold growth, you can break the remaining crystals that form the block so that the crystalline mass display look more natural from the geological point of view. to expose the glass, LED lights the base by pressing the button on the bottom. transparent glass placed at the base and see how it changes color. if you are not using the base, be sure to extinguish by pressing the button again. to replace the battery, remove the cover with a screwdriver as shown below. NOTE: with the help of a magnifying glass, look closely at the detailed crystal structure of the crystals finalized.
Beak-shaped crystals: follow steps 2-10 with the following changes: In step 2, only 0.34 a boil water. In step 3, use the contents of the bag 11.
In step 6 uses the five molds size "D" of growth of crystals with a single rock in each base.
In step 8 uses color guidelines mold "D" (crystals spike) in the diagram below.
NOTES: replacement of the battery base. Place the base upside down. Now you can remove the battery cover to access it, as shown in the image below.
Jan 10, 2011 | Edu-Science Toys
Brand new toy came without instructions. Please send them for the "made by me!" trademark Power Balls. This is a create your own new product. THANK YOU!!!
The instructions are fairly simple.
1. First, gather your materials. In addition to the kit, you will need a glass (large enough to submerge the assembled mold), water, and a timer.
2. Choose the colors for your ball. Any combination of colors from a single color to several different colors, mixed together, layered, or whatever you can imagine.
3. Assemble the ball mold. The molds come in just two pieces each that snap together easily.
4. Pour the crystals into the mold (make sure they are packed down to insure there are not air bubbles), according to your color design plan. Fill up the mold to complete the proper shape of the ball.
5. Place the filled mold into the glass and fill with water to the top of the ball mold (allow a small amount of water to flow into the top of the mold). Let sit for 5 to 10 minutes.
6. Remove the mold from the water, carefully remove the mold from the ball, and allow to dry.
Tip: A submerging time of 5 minutes is not long enough for most molds; to ensure all the crystals are thoughly wet and a strong ball is formed, 10 minutes is optimal.
Jan 05, 2011 | Toys
Water leak on rear driver's side after a moderate to heavy rainfall. Car is 2002 Passat. Help, please. A good amount of water is collected, and it is only on rear floormat of the vehicle, driver's side.
Bummer, lift the carpet and pad to properly dry the area. you will have mold and musty smell forever if not completely dry. ideally with a fan.
Look at sunroof drains, look at door drains and door seal. Look in trunk, look at back glass.
Oct 09, 2010 | 2002 Volkswagen Passat
How to remove rust looking stains on outer doors
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Apr 28, 2010 | KitchenAid Superba Architect KSCS25IN Side...
I have a rattling sound in the dash passenger side that I only hear at around 60 and up MPH. Seams to be from some type of windnoise but I havent found anything loose in the dash.Has anyone else ever...
The side windshield moldings are your problem. Gm has an updated version but i wouldn't spend the money on them.
There are 5 screws holding the molding on. Remove the molding, clean both the window and the molding with a good glass cleaner. Put a strip of 1/2 inch double sided tape on the windshield edges then install the molding. This should take care of your problem.
Nov 11, 2009 | 2002 Chevrolet Silverado 2500HD
How do I replace the back window?
Remove the black vinyl trim from the edge of the glass. Remove broken glass & urethane adhesive from the metal pinchweld leaving a thin layer (approx 1/16") of urethane for new new urethane to adhere to. Vacuum broken glass. Prime nicks to the metal to protect from rusting (also insuring a good surface to bond to). Attach vinyl reveal molding to glass (unless it's a "T" shaped push in type - it would install after the glass is set). Clean and prime the replacement glass. Apply new urethane adhesive. Set glass in place.Slide the metal joint cover in place on the molding (at bottom in the center). Clean outer surface of glass. Allow for safe drive away as noted by urethane manufacturer.
Sep 25, 2009 | 1995 Oldsmobile Cutlass Ciera
Remove the lower window molding on2000 durango
For the lower belt molding?
1.lower glass
2.Lift corner of weatherstrip upward and remove weatherstrip from outer door panel.
Apr 27, 2009 | 2000 Dodge Durango
Dishwashers Logo
62 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
