Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Vibration We have our washer on a pedestal. When it goes into the spin cycle is vibrates pretty badly. According to the level, it is level, Left to Right, Front to Back and diagonally. I've heard of people using some sort of rubber matt to absorb some of the shake. Do you know what type of pad this is or how to stop the vibrating. Love the machine otherwise.
  • 2 more comments
  • JonSheldon Nov 03, 2007
    I've got the same problem when the washer spins on anything from medium to high.  It sounds as though a helicopter is landing on the house.  The LG folks say we need to reinforce our floor!!!  Rebuild my house for an expensive washer?  We've carefully leveled it and insured the floor is as solid as possible.  Next thing we'll try is a "stall matt" - a rubber matt for farms.
  • jdix May 05, 2008
    LG TROMM SteamWasher. Bad vibration every time it spins. No shipping bolts. Floor on 2x8 joints, 1 inch subfoor and overlayed with ceramic tile. On pedestal and has been adjusted and leveled several times. My son has a Whirlpool and has no such problems. Sure would like to know what to do.
  • johndigbydog Oct 27, 2008
    I have a Kenmore HE5, now 2 years old. It is now vibrating badly when in the spin cycle. The shipping bolts were removed when new. It seems something has worn out already, not good for a $1200 washer! I am told the parts are all cheap plastic! What can be done?
  • leanne hayter Jan 13, 2013
    I am purchasing vibraton pads called vibrafix pads. They haven't arrived yet but will let you know if they help. Our washer is also on raised floor. I wish they had of told us that front loaders are designed for concrete floors.
Vibration problem fixed!!  If your washer vibrates excessively, check to be absolutely sure that whoever insalled it removed the drum locking bolts (4 big bolts on back of machine).  My store installer didn't ,and the machine danced across the room.  Second appliance repair fella (he was here for something else) removed the bolts, and voila - problem solved.  Problem is he says in the three times I used it before the bolts were removed, I may have done irreparable damage (imagine the resistance with the washer trying to spin while bolts have locked it down to prevent this action).  So I'll go back for a replacement, but in the meantime, it works and vibration is entirely reasonable, and my machine is on a crappy wood floor (not concrete).
Posted on Oct 26, 2007
  • 164 Answers
Just because the level shows it is doesn't mean it really is. check the pedestal first. make sure it is level and all legs are tight and there is no wiggle. next do the same for the machine once it is put back on the base.
Posted on Sep 19, 2007
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Tip
Front Loader Excessive Vibration
When the manufacturers first introduced the front load washers, they did not take into consideration the possible problems created by the centrifugal force of the washer's spinning action. Most of these washers spin in excess of 1200 rpms! A spinning action that fast, coupled with the washers heavy weight and a floor that flexes (even a little) will cause a resonant vibration. In simple terms, it will cause the washer to bounce or walk.
Some of the early manufactured shock absorbers, weren't up to par and were uable to maintain the washer suspension over continuous use. The manufacturer's improved the shock absorbers to make them more stiff and minimize vibration. Replacing the shocks with heavier duty shocks does help, but if the flooring is not substantial enough the washer will continue to have problems.
If the washer is mounted on a pedestal, this can make the problem worse. Early model pedestals had an open back which caused it to "tin can" when the washer spun. "Tin-canning" is the phenomenon of the sides of the pedestal casing waffling in and out as the weight of the washer rides on top of it. This would also cause excessive vibration. The solution: The manufacturers redesigned the pedestals with an enclosed back that would prevent this from happening. If your washer is a later model, you should have an enclosed back on the pedestal. If there is no back panel, a stiffiner kit can be purchased and installed by any Do-It-Yourselfer. All you need is a drill and a screwdriver. Instructions are included. The part number is 134682000. I found it listed at searspartsdirect.com.
Check the leveling of the washer. You need to adjust the feet of the washer ensure it is level front-to-back and side-to-side. The feet are adjusted using a wrench to turn the legs up or down. Use a level to check your work. Once completed, you should be able to place your hands diagonally across opposite corners of the washer top and see if the washer moves at all. If unlevel (just the slightest) the washer will vibrate during the spin cycle. If the washer is mounted on a pedestal, you level the feet of the pedestal, NOT the washer. Make sure the washer is firmly mounted to the pedstal fisrt. Then, level the feet of the pedestal using the same procedures outlined before.
Another cheap method to get rid of vibration is to use foam padding to sandwich between the sides of the washer, the dryer and the wall. Swimming pool noodle foam works real well and is very inexpensive. About $3 or $4.
Overloading the washer with heavy items can cause excessive vibration due to an unbalanced load. If you load items so full that you can barely close the door, the load will have a hard time distributing evenly around the perimeter of the wash tub. Once wet, and the tub begins to tumble, the load becomes entangled and will pack on one side of the tub. This will cause the washer to jump and walk across the floor on the spin cycle. This can also cause premature wear to the door bellow, damage to the door latch and damage to the shock supports and counter-weights. Always follow the manufacturer's wash load recommendations as outlined in your owner's manual.
Now...when you've checked every other possibility, its simply not the washer. Most consumers don't like to hear this (especially owner's of newer homes). The worst places you can put a front loading washing machine is in a mobile home, or an upstairs laundry room. The floors in these areas are usually not as reinforced. Even homes with a laundry room over a crawl space or basement can sometimes have problems if the floor flexes. Most home builders don't take added reinforcement into consideration for the installation of a front loading washer.
An inexpensive way to reinforce a laundry room floor is to install a 4 x 8 sheet of heavy plywood under the washer. The plywood has to be a minimum of 3/4 inches thick and needs to be secured (screwed down) to the existing floor. This distributes the weight of the washer better. You can also safely fit BOTH the washer and dryer on top of it. A lot of people don't like this idea, because they feel it wrecks the look of the existing floor. I have seen homeowners, install a reinforcement this way and add paint, trim molding, and even tile to give it that "supposed to be there" look.
You may get mixed reviews about this, but I have seen it work for homeowners. Plus, its a less expensive option than hiring a contractor to firm up your sub-flooring or joists.
I hope you find this information informative and helpful. If you have questions, please let me know.
on Dec 13, 2009 | Washing Machines
Experiencing extreme vibration and noise with my LG WM2101H...sounds like a rocket is taking off everytime i wash something...it's on a pedestal, overflow pan and is located on the second floor...no...
This is actually pretty normal for newer LG front loaders. They've done a lot of work to isolate the vibration and noise from the spin cycle, but the higher RPM's have countered those improvements. Unless the manufacturer/technician can determine that something is actually wrong, you're probably going to need to install an anti-vibration pad under the washer pedistal to absorb most of the noise. It is very likely that the subfloor is actually amplifying the vibration into the "rocket" noise that you are hearing. Try installing Silent Feet anti-vibration pads or similar to prevent this amplification of the noise and vibration.
Mar 04, 2010 | LG WM2101HW 4.0 cu.ft. Washer
My LG WM2233HW vibrates and crawls forward during the spin cycle, it is not on a pedestal, does anyone nkow if the pedestal will stop this?
Not sure what pedestal you refer to ,but vibration and movement is often caused by machine not being level / not stable initially . With machine off ,hold the top firmly and see if you can rock it in any direction , if you can , put some packing under the base to stop this , then operate machine , it should be better.
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Vibrates badly
did you remove the shipping braces when you installed it you can find their location in your owners manuel under installation
Mar 28, 2008 | LG WM-2277HW Front Load Washer
Kenmore washer model 41740042990
Even after leveling my Frigidaire washer on a pedestal, the washer shook the house during ramping up on spin cycle. I found some Shake Away pads at Lowes. They are small pads that just go under each foot of the washer. I'm not sure how they work but THEY DO. The best 30 bucks I ever spent
Sep 16, 2007 | Washing Machines
Friadaire washer on a pedestal
Check the levelness of the washer by placing a level in the crease between the top of the washer and the cabinet, first on the front and then on the side. If the washer is not level, adjust the relevant feet up or down as necessery by twisting the feet. Repeat the process until washer is level. Tight the locknuts tight against the washer cabinet to prevent washer's vibration. Good luck!
Sep 08, 2007 | Washing Machines
Washing Machines Logo
562 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
