Question about Dell Vostro 1400 Notebook
Dell Vostro 1400 black screen on boot
how: I played a PC game when suddenly the screen froze. I turned it off and on again, the screen went black.
warranty: expired a month ago...
i tried: to insert an AC adapter, nothing happened. I can adjust the light on the screen (FN + up/down).
help?
How to boot my dell vostro 1400 from usb CD/DVD Drive
Go into setup (F2 during initial boot screen) and change the Boot menu to reflect the CD/DVD drive being the first boot device. THEN place a bootable CD or DVD disk in the drive and reboot your computer. When asked if you want to boot from the disk, click any key immediately.
Jun 19, 2014 | Dell Vostro 1400 Notebook
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
I have a Dell 1400 vostro when I turn it on it goes to the dell screen with the loading bar on it but will not go any further when I did diagnostic it said the everything was working
Hi there!
For this problem the cause can be a software update that blocks your windows to load, Now to fix this you can go to the safe mode which is by pressing f8 while starting up your computer. After that you should be able to access your computer. If it still won't load try to check on which line it will stop in safe mode and that is the one causing the problem. But if you're successful in booting to safe mode try to disable the startup items and services by going to msconifg. Hope This helps!
Jan 04, 2011 | Dell Vostro 1400 Intel Core 2 Duo T5270...
I have a vostro 1400 model with a nvidia 8400m gs GPU. my laptop turns on the screen too, but remains always black. overheating gpu brings it to life, but only for a week. is there any solution?
Based on the symptoms provided, the issue is hardware related. Installing the Drivers such as Video card, BIOS update etc will not resolve the issue efficiently..
Jul 04, 2010 | Dell Vostro 1400 Intel Core 2 Duo T5270...
HP Compaq nc6220 freezing up problems? Hey all, I've been having a problem with my notebook. I was recently playing a game on it when it froze all of a sudden. I couldn't move the mouse or anything so I...
old relic puters. near useless now.
what OS? operating system
what game, name it>(solitaire?)
you cant just sway HDD<
the HDD put in alien must be freshloaded with the correct HP
windows, disk.
2005 is first year made
old that is,
here is a black screen page with simple tests
test 1 does bios screen work.
i bet yes
so reload the oS disks from HP
sold with windows 2000, XP and Vista.
which one you have only you know;
http://jeepdied.com/look/puters/dead-screen.html
Mar 23, 2017 | HP Compaq nc6220 Notebook
My Dell Vostro 1310 won't turn on. I get a black screen (well actually, a bit of colors are coming, but nothing else ...). Tried again and again to turn on, seems to be a problem with the video card....
check for led lights if they come on.
note down the lights.
If you are able to remove the connection of the lcd to the laptop do so for instruction refer to www.dellsupport.com click on manal
Oct 05, 2009 | Dell Vostro 1310 Laptop Computer PC...
Dell Vostro 1400 LCD Showing Black Screen
If you can't see it with an external monitor - it generally means the system board needs replacement. I hope that you still have a Dell warranty. Good luck.
Jun 09, 2009 | Dell Vostro 1400 Notebook
Dell Vostro 1400 Notebook Logo
254 people viewed this question
Alun Cox
