Question about Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP SUMP PUMP W/TETHERDFLOAT
Little giant pump stopped working - Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP SUMP PUMP W/TETHERDFLOAT
  • 1,498 Answers
Hi Tom (and Lindsay?),
Ok lets get a little more info,
  1. Plugged in? (Have to ask)
  2. Does it run and not pump?
  3. Does not run?
  4. Tried moving the float switch?
  5. Pull the pump and see if the intakes are clogged
Please comment back with your findings
Mike
Posted on Oct 22, 2009
I have a Little Giant 6CIA submersible pump for about 3 years now, used once an in a trap in the basement waiting for a flood. Tried to test it today submersed and it would not work, banged it around a...
This pump works off of a pressure switch. You can remove the cover on the switch located on the side of the pump.You can either buy a switch repair kit, or you can open it up and take a look and see if the diaphragm is sticking. If you remove and clean the parts, you may have some success. Or, just buy the switch repair kit from your local Little Giant dealer. Good luck!
May 02, 2017 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
My new Little Giant 8-CBA Pump is hooked up underwater and plugged in. Not a sound. Electricity is working. And it's the same pump we have had for the last 7 years.
You say it's new? On some pumps they will secure the float switch when shipping. Be sure you followed directions and removed anything that may interfere with the switch.
Apr 21, 2011 | Little Giant 8 Cba, 4/10 Hp, 45 Gpm...
Only way to shut off Little Giant sump pump is to unplug it. What is making it run all the time?
Assuming that your pump has a built in float switch, I would suggest that the float switch is frozen, stuck or damaged. If you have an underwater pump that does not have such a switch then it probably is designed to only be used manually. I have a little giant pump which is designed to go underwater but must be plugged in to use and unplugged to stop. I'm assuming you have had this pump a while and in the past has always worked automatically. Again , if yours is automatic, it's the switch. Unless it's a simple thing like a frozen arm, I doubt you can fix it unless you can replace the entire waterproof assembly without tearing into it. It must remain waterproof to be electrically safe.
You may find that only a factory repair will be the proper solution.
Nimsgame
Feb 15, 2011 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
My little giant just stopped working, impeller turns ok by hand, no blockage, 110v to outlet ok. Always under water, never ran dry... Walter
inside the pump on the motor is a thermal cut out if the motor has over heater from running a long time the cut out pops and it may not pop back in again? its that or there is a motor fault like brushes worn out
Aug 28, 2010 | Little Giant 5-MSP Water Wizard...
Hello, my little giant dinosaur pump stopped
No reset, the pump may have just failed internally, try another plugin to varify power, if no joy than look at a new pump
May 14, 2010 | Plumbing
Sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Jul 06, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
Jun 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP SUMP PUMP W/TETHERDFLOAT Logo
623 people viewed this question
Top Franklin Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Franklin Garden Expert? Answer questions, earn points and help others
