After turning power on to the amp ta-av531 and try to play a cd or listen to radio it seems like the tuner shorts and the amp with go off. if you hit the side on the amp it will sometimes come back on. the tuner is a st-jx431. please help anyone
xalint1
  • 150 Answers
SOURCE: Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Posted on Jul 30, 2008
SOURCE: Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Posted on Nov 23, 2008
  • 57 Answers
SOURCE: Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Posted on Jul 06, 2009
SOURCE: wire for st-jx285 tuner and a integrated amp. ta ax285
I too have the same system. STJX285 however I only have the #1 cable and need the #2 cable. the system I have is complete including the cd player and dual cassette deck. You would not happen to be willing to part with your #2 cable would you? you can contact me at frankgamboa@msn.com
Posted on Apr 30, 2010
eliezerpenny
  • 236 Answers
SOURCE: I have been given a Technics system with tuner (st
What AJIN GOPAKUMAR says.
You can buy cables and speaker wire at Best Buy, Wal-Mart, Parts Express or Amazon. Even a "dollar store".
One thing to keep in mind - do not fall the hype of people who want to sell you very expensive cables because they will sound "better". $2-8 for a set of RCAs should do nicely.
You don't need Monster Cables or their even more expensive brothers. There are many cables that fit your needs. One example on Amazon is "Hosa Cable CRA202 Dual RCA To Dual RCA Cable - 6.5 Foot". Another is Parts Express's "RCA Patch Cable 6 ft. Gold Plated" for $1.80 plus shipping.
More expensive cables will not hurt anything. But they won't help anything in your set-up.
And keep them short, if you can, for neatness ... though long ones won't hurt anything.
Before you buy speaker cable do some measuring ... and add several feet. You will be just fine with lamp cord or zip cord from a hardware store. "Speaker cable" is the same thing with clear plastic covering, often color-coded. This can be helpful because the most important thing to know about wiring speakers is that the MUST be in-phase -- red to red and white-to-white, or plus-to-plus and minus-to-minus. THIS IS VERY IMPORTANT! Check and double check!.
Posted on Oct 25, 2012
The volume is noticeably lower when listening to the radio. It sounds normal on CD, Aux and MP3. I know it has a built in amp. Could this be the issue. Thanks.
You have not mentioned what type of radio you have, what car it's installed in, and what other audio equipment you have. I will assume it's an aftermarket radio, and it's common that the tuner's signal strength is not going to be as powerful as the other sources. If the built in amp is used, then it's used all the time, with all sources, including the tuner. Some brands will have a loudness offset function wherein you can lower the power output of the CD/Aux/MP3 inputs to volume match the radio, but there's no fun in that. There's not a way to make the tuner play louder, unfortunately, aside from adjusting the volume when using the tuner section. Technology has brought many advances, including a much higher signal to noise ratio, which is why digital trumps analog in this instance. This is what you are experiencing, which is not necessarily a technical issue, but a technology issue.
Jul 02, 2017 | Car Audio & Video
There is a beeping noise coming from my Blaupunkt Nashville DAB35, how can i stop this?
Have you recently disconnected the battery or pulled the Blaupunkt out as the beeping is usually due to requiring a code.to be entered into the Blaupunkt
Aug 24, 2010 | Blaupunkt Nashville DAB35 CD Player
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
2004 freestar can't turn the radio up or down it
I would question your children " if you have any" if they have put anything in the cd slot, I work at a dealership and we find a lot of problems with the van radios are very nice children like to play and put small change into the cd slot, which shorts out the internal components of the radio, if you remove the radio, dash piece just pops off then 4 screws hold radio in, and shake it you should not hear anything rattling around in it.
Jul 16, 2009 | 2005 Ford Freestar
Sony output problem
Nov 22, 2008 | Sony TA-E9000ES Amplifier
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
No Subs in CD mode??
Ah, common problem. You hooked up the remote turn on wire for the amp to the power antenna wire (solid blue). Hook up the remote turn on wire for the amp to the blue wire with white stripe. The power antenna only provides power when the deck is in tuner mode for the power antenna to be extended, intuitively, and cuts power in any other mode, because certainly it's only needed for AM/FM reception.
Sep 28, 2006 | Sony CDX-M8815X CD/Receiver/MP3 System
No sound with discs playing
There should be some sort of outboard amplifier. Mine had an amp at each speaker, and also a receiver mounted behind the passenger seat. Could it be that the power antenna lead from your headunit is connected to the amp turn-on lead? That way, when the radio is playing, the antenna lead is powered and thus the amps are too, whereas when the CD is playing, the antenna lead would not be powered and thus no sound. Try reversing these two wires (Power antenna and amplifier turn-on) and your CD should work.
Jan 21, 2006 | Jensen VM9410 Car DVD Player
111 people viewed this question
 Grubhead
Grubhead
