Question about Roper RGX4634KQ Gas Dryer
How do i open the machine to get to the coil valve/ do i remove the blower wheel? and if so how is that done (roper mod# rgx4634jq0)
  • 460 Answers
Here are the break down diagrams and Replacement parts for WHIRLPOOL RGX5634KQ2 |
AppliancePartsPros.com
Did you check the element?
Check if glow?.
also checked the continuity of the flame sensor.
If is good.
Am I to assume then that the heating element is bad? Or could there be another issue?
thia mean that the thermal fuse is bad.
You need to replace along with the cycling thermostat and see what happens.
"Did it solve your problem?"
Posted on May 08, 2009
I HAVE A Roper heavy duty 8 cycle 2 speed combination water won't come into washer machine nor will it work on any wash cycle, but will spin
If u have no water I SUGGEST CHECKING WITH A METER UR INLET WATER VALVE THE COILS MAY HAVE GONE BAD
ALSO MAY WANT TO CHECK THE WATER PRESSURE SWITCH MAY BE STUCK OPEN
Jun 02, 2015 | Roper Washing Machines
Won't start roper dryer door closed properly still
Hi bootywatcher...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Sep 28, 2012 | Dryers
Roper dryer model REX6634PQ0 doesn't heat... suspect heating coils bad, perhaps also fex-vent hose may be clogged... otherwise dryer works, including timer.. done so far.. cleaned vent hose...
Start by unplugging the machine and take it outside if possible.
get the screws out and remove the rear cover
Go ahead and get the front off next so you can remove the blower housing
Take the filter out and a couple screws then grab the back of the control with
your left hand and use a putty knife to release the top on each side
That smaller fuse at the top blows with a blocked vent
8_17_2011_4_03_01_pm.jpg8_17_2011_4_03_15_pm.jpg8_17_2011_4_03_40_pm.jpg8_17_2011_4_04_15_pm.jpg8_17_2011_4_04_45_pm.jpg8_17_2011_4_05_01_pm.jpg
Service manual and videos are HERE
Aug 17, 2011 | Roper REX4634KQ Electric Dryer
I need to replace the water valve, but dont know the best way to access the old valve. I have Roper Model RAS5133EQ. I have the new valve but don't know the proper way to install it. I don't know how to...
There are 2 screws on the front or back of the control panel that are angeled in remove them then remove the lid switck connector & 2 clips then remove the cabinet. watch this viedo http://www.youtube.com/watch?v=6XIsK3W_Qcg
Sep 29, 2010 | Roper Washing Machines
My roper dryer is not heating only blosing cool air rex 3614pwd
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 10, 2010 | Roper Dryers
My roper rex3614pwd is bloeing cool air every thing else works..what is wrong with it
Please rate me
Sep 10, 2010 | Roper REX3614KW Electric Dryer
ROPER RGS7745RQO IGNITER LIGHTS BUT WILL NOT FIRE ONCE WARM, FLAME SENSOR ALREADY REPLACED
2-3 possibilities....no gas coming to machine,bad solenoid valve coils,bad valve period....probably the coils
Mar 03, 2010 | Roper Dryers
Roper rex351 dyer not getting warm
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
Dec 05, 2009 | Roper REX4634KQ Electric Dryer
Dryerdoesn't heat up. Have checked circuit breaker       It is a Roper electric dryer  MOD RE87745P00         DWJR-ELE-2406028-FM54        ...
Check to make sure you are getting full 220 Volt power to the dryer, if you are then: Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
Dec 04, 2009 | Dryers
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
173 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
