Question about Panasonic Lumix DMC-FZ7 Digital Camera
Picture not focused at 12x zoom
After using DMC-FZ7 camera for a year, I can no longer get a focused picture at long zoom lengths. After moving the lens to 6x or 7x and beyond, the picture on both the LCD and after it's taken is out of focus. This happens outdoors with landscapes, fixed images on buildings, etc. I used to have clear images at even 12x. thanx
  • kwest2008 Sep 19, 2007
    Your hint about focusing in manual mode was helpful. I tried several things and here's what works. If I go to Simple Mode, it focuses correctly at 12x; if I then go to other modes like Program, Aperture, Shutter, it will focus at 12x. BUT, if I go to the other modes FIRST, before Simple Mode, when I turn on the camera, it won't focus. I then go to Simple Mode, it focuses, then I can go back to the other modes. There must be some setting in the camera that I changed or need to change.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Posted on Sep 19, 2007
  • scott gregg
    scott gregg Sep 19, 2007
    I did check the website and if it still refuses to focus even when using the manual focus you really need to have it checked.
  • scott gregg
    scott gregg Sep 20, 2007
    try to do a manual reset or switch everything to default in the setup mode. Thats the only advice i can give since i dont know what you might have changed or what your settings r now.
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
My zoom is behaving badly...camera is working fine ontil i want to use Zoom ...it will not stop until it reaches the 12x position ...takes photo here fine but nothing inbetween ???
Sounds like the zoom switch is broken. Repair is possible, but is best left to a professional technician. Check with your local service centers.
Jul 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
DMC-FZ7 Panasonic digital camera won't focus when zoomed
Your camera focus problem mostly deal with machanical parts. So changing them easily will solve the problem. But unfortunately you may not do it yourself. Because it is highly complicated process. In deed it needs lots of repairing devices which are found only in services. According to me the service had given you the best answer. Please accept their advice. Good luck.
Mar 04, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
Dec 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Close up shots won't auto focus.the lens trys to adjust but the final setting is out of focus. the camera works fine on subjects at least 2 feet away
try using the little throttle that is located just below your on/off switch. if you push that either up/down, it should help you manually focus your subject. It is actually a really fun feature to play around with.
Feb 28, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Focusing
On most digital cameras you can point at an object centred in the lens and hold the shutter control in slightly, them move the camera to another area with the focus/exposure set. If your camera gets it's focus as an average of multiple points this may be a little tougher.
Regards
Philip
Jul 31, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a panasonic lumix dmc-fz7. the zoom lens no longers adjust even though it moves when powering on and off. the button used to move the zooms works to move between pictures. the camera has not been...
after a bit of research i powered off the camera removed the battery and powered it on. i then recet the it to the factory defaults and it worked fine again.
Apr 04, 2008 | Panasonic Cameras
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
If you zoom to less than 12x
The macro setting on the fz series allows you to get within a couple of centimeters of the subject and obtain focus. That is pretty close. That is too close. The camera will throw a shadow. You need some room. Most high zoom cameras (notably Olympus) have macro capabilty throughout the zoom which not only increases the magnification but also allows you (requires you) to put some distance between the lens and the subject. The panasonic fz series is different. They do not have macroability at zooms greater than 2x-3x. Beyond that there is no increase in magnification. Why? I dont know. Maybe this feature was designed on a Monday. Fortunately this can all be rectified with the use of a closeup lens. Now the fz series will react like most other high zoom cameras and do it well. The Olympus b-macro is such a lens. There are many others
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Sorry you're having such a problem with the fz1 w/b-macro. Here is a shot of the stock fz1 w/b-macro at full 12x zoom - resized only. Try practicing on still objects such as coins or jewlery. If you are beyond 10-12 inches you are probably too far away.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
129 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
