Question about Kenmore 62702 Microwave Oven
How to remove a Kenmore over the range microwave model 85770
I have found the 2 bolts in the cabinet above. Before I unscrew them, what is the next step to get this off the wall?
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9098 Answers
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
Remove microwave built in range
I) empty the cabinet above the unit.
2) unplug the unit from the outlet in the cabinet
3) locate the two bolts near the front edge in the floor of the cabinet and remove them. the unit will tip down to the range below.
CAUTION SUPPORT THE UNIT WHILE TAKING OUT THE BOLTS OR THE UNIT WILL CRASH
4) Two people can then lift the unit from the support on the wall.
Aug 22, 2014 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Want to remove an old jenn air microwave Model # M438B. Removed the screws in the cabinet above but its not budging. What do I do?
There are probably a couple of long bolts still holding it to the brackets on the back wall.
These long bolts are usually accessed through the removeable grill on the front of the microwave.
Just pop off the front plastic grill and then unscrew the bolts underneath. Be sure you have someone to support the full weight of the microwave when you do this since it will probably drop down once you remove these 2 long bolts.
Here is a link to a few other articles with some more tips:
http://wiki.answers.com/Q/How_do_you_remove_an_over-the-range_microwave
http://hubpages.com/hub/how-to-install-installing-an-over-the-range-microwave
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 28, 2011 | Microwave Ovens
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Jan 21, 2011 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How to remove from wall for remodel project
There are 4 bolts or should be 4 holding the microwave top to the cabinet. Open the doors to the upper cabinets and you should see the bolt heads unplug the microwave unscrew the bolts while holding the microwave. After the bolts are out tilt microwave towards you and pick up from the bottom next to the wall to remove oven from mounting plate and thats it.
Sep 16, 2009 | Sharp R-1505 Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Sep 23, 2007 | Microwave Ovens
Kenmore 62702 Microwave Oven Logo
378 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
