Question about Dell Inspiron 1525 Notebook
Won't turn on
When depressing the on button, nothing happens...lights flicker as if the unit has power....same when plugged in or running off battery. Any suggestions? Had laptop about 2 months.
  • 107 Answers
Try to diconect power cord and a battery and leave it for 10-20 min. Then plug them back. I solved once such an issue with MSI Gaming notebook GX600.
Good Luck!
Posted on Apr 18, 2009
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
I have an IBM T40 that worked great until yesterday. When I powered it up, the 4 lights (battery, etc) flickers but the laptop does not power up. I removed the battery, paused, tried with and without the...
There are a few things left you can try. First take the battery out and make sure the unit is unplugged. Next push the power button a few times to discharge any power inside the unit. Now put the battery back in and while plugging in the unit see if the charge light comes on or flickers at all.
If it flickers and goes out, you have a bad power cord or worse a bad jack on the laptop's main board. If it never comes on, you have a bad power cord or mainboard. The battery is probably dead (doesen't have a charge left in it.)
You said this happens regardless of if the battery is inserted. Have you tried powering up the unit with no battery installed and just the power plug?
I'd see about gettting a replacement cord first. If that doesen't do it you probably have a bad board.
Oct 17, 2010 | Computers & Internet
No screen no nutthin'.
Sounds like you may have motherboard issues. it would not be worth the expense to consider repairing this unit.
Jun 14, 2009 | IBM ThinkPad T20 2647 Notebook
Won't turn on, black screen
seems to be a hardware issue (not easy to diagnose over the net) I would take it into a shop and have it looked at.
May 28, 2009 | Dell Inspiron 1525 Notebook
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Each time i try to turn on my Toshiba Satellite L305 ( laptop), the on light goes on, but nothing else happen's, the hard drive light does not flicker and the screen stays black. The airport light usually...
Removed the power conection and remove the battery as well and press and hold the power button for 5 to 7 sec and then connect the battery and power cable and try to turn on
Regards
Samson Ved
Dec 05, 2008 | Computers & Internet
Toshiba a60???
if this happens even if your laptop is plugged in to a power source it could be that your battery is dead and you need to replace it
May 21, 2008 | Computers & Internet
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Dell Inspiron 1525 Notebook Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
