Question about Storagetek L40 DLT Tape Drive
StorageTek L40- Service required Led Blinking always.
Hi, I have a StorageTek L40 tape library with two LTO2 drives. The service required LED is blinking always in the library. Now its detached from the server. Once its connected with the server the server gets crashed. I have removed the all the cables (except power cable) and powered On. But still its states that service required... I couldn't find whats the problem exactly.. Please help me to resolve this issue. Thanks and regards, Sudhakar.m [email protected]
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Posted on Jul 03, 2008
SOURCE:
Failing to recognize tapes in Sun StorageTek C2 tape library
Are you seeing a cleaning light or is it just ejecting the tapes? If it is ejecting them then make sure to try a brand new tape of the right type (if it is the wrong tape type it will eject).
Also try a cleaning tape if the cleaning light is on.
If that does not work then you will need to send in the tape drive somewhere for repair as the head might be worn out or the drive needs a good service.
Try going to http://tape-drive-repair.com who sell and repair these units. The LTO2 and LTO3 drives are pretty inexpensive now and so this should be fairly cheap to have sorted.
Also this unit is the same as the Quantum superloader3 so that might help if you are still googling for a solution
Sep 05, 2013 | Computers & Internet
Tip
HP Tape Library Maintenance
Do Not clean the tape drives in a HP tape library unless and until the cleaning LED blinks. It is strictly recommended by HP.
Also do not fill all the slots with media, always leave 2 slots free apart from the male slots. This helps to avoid media struck in the library.
on Mar 21, 2010 | Computers & Internet
Proximity detector off failed
Hello!
I had the same problem with our Storagetek L40 library and had to get another robotic hand from a company named Instock Inc.
It was an easy fix. I just had to power off the L40 library, take off the old hand and put the new hand on, then turned the L40 library back on, and it worked great after that.
In the hand is a sensor that goes bad after time.
You should be able to find them on the web at instockinc.com I believe, and they should have the hand you would need.
Jan 26, 2011 | Storagetek L40 DLT Tape Drive
Service Required message
maybe you can try to run a cleaning tape see if it help ... else getting a replacement for Drive 3 would be your next available option.
Jan 14, 2009 | IBM (18P7473) LTO 2 Tape Drive
Error Code 3112
3112
ERR_ITL_DETECTOR_OFF_TEST_FAIL,
The test for the proximity detector off failed.
FRU: LOCATION: CONFIDENCE %:
HAND ASSY LSM 90
LLC LCU 10
Check the hand
Aug 27, 2008 | Storagetek L40 DLT Tape Drive
ADIC Scalar 24 LTO2 Drive issue
We have the same problem with our ADIC Scalar 24. The only way we have been able to eject the tape is to cycle power on the tape library and after it has finished reading the tape barcodes, we can use the front panel command to unmount the tape that is in the drive. We haven't been able to find a solution to the problem and it happens at least once a week
Mar 29, 2008 | ADIC Scalar 24 (90079801) LTO 2 Tape Drive
StorageTek L40 Tape Library
sounds like your robot is stuck or something may have dropped onto the track on the floor which is restricting it's movement.
Jul 26, 2007 | Storagetek L40 DLT Tape Drive
Service required led blinking
You will need to get a StorageTek engineer out onsite to have a look at the problem, the light will not dissapear until resetted by a engineer.
Jul 10, 2007 | Storagetek L80 DLT Tape Drive
Storagetek L40 DLT Tape Drive Logo
381 people viewed this question
Top Storagetek Computers & Internet Experts
Ekse
Alun Cox
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
