Question about Panasonic PT-51HX41 51" Rear Projection Television
Convergence amp what makes a convergence amp short out in this product?
    President:
  • 3,130 Answers
Heat or not using the right replacement IC if it keeps burning out. If it is the first time it happened, the heat sink compound dries up, and then the heat transfer goes down and the IC overheats. If the IC is burning out a short time after you replace it, you are probably using a cheapo aftermarket type or a factory reject IC. You need to use an original replacement, not just one with the same numbers because all IC's are not alike, even with the same numbers. You also need to put new heat sink compound paste on the back of the new IC's before you replace them.
Posted on Sep 19, 2007
SOURCE:
Hitachi 53" projection
there might be some resistor that shorted
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Samsung PCL542R the Timer light is on and TV will not turn on
TV is in shutdown, may be caused by a shorted convergence amp IC. Also could be caused by any short in secondary B+ supply. Unplug supply to converg amps, if TV comes on, but out of convergence then you have a shorted IC, STK-392-010
Mar 10, 2009 | Televison & Video
First color alignment problems then no pix or sound, just chirpin
If the unit is chirping your convergence amps are out again,or you have a shorted Horzontal output transistor. Not likley for horz output to go out after convergence repair. If he did not replace the 6.8 ohm resistors along with the convergence amps the convergence amps would overheat and short out again.This would explain why the corner would not adjust out. Not a very good buisness practice on his part.Here today gone tomorrow?
Jan 15, 2009 | Philips 60PP9202 60" Rear Projection...
Magnavox 51MP392H Convergence Amps
I always stick with the OEM stk #'s - for one..... also it sounds like you may have some damaged resistors in the convergence section. Pull one leg of each resistor and measure the impedance of each one to make sure they are in spec.
If you need a service manual, go to techlore.com , click the Resources tab, then click technicians corner. You will be ale to click "see all downloads" and look for the magnavox 52mp392h/17,
or you can try this link:
http://www.techlore.com/group/2/list_downloads
hope all this information helps!
Jan 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Wont turn on
work around convergence check voltage to convergence IC's if is ok, I' had same problem. find out one of the ic's was shorted
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Magnavox Projection Model # 9P5034 C101
Yes you will need to discharge any electrical equipment before working. One way of doing this is keep equ. unplugged for sometime or after unplug short hot to ground which will most times cause a spark. You can go to vancebaldwin.com or andrewelectronics.com or any online parts store and get the part number off old IC, yes these are on the convergence module. They are big STK's, also there are resistors that will need to be changed and maybe pico fuses.
Jan 05, 2008 | Philips 9P5034C 50" Rear Projection...
Amps replaced...still getting 3D pix. The amps are not getting power. HELP!
Hi Brulia
There should be approximately 8 to 10 fuseable resistors around those convergence ics. They should stand out as they are a bright yellow colour. You should measure a short over them. If none of these are faulty I would leave the supply to the convergence alone and rather check the +5V / -5V and +12V supplies used by the convergence logic ICS. A common problem is the - 5V supply also used for your HT-protection cct op-amps. These ics goes short and pulls the supply to ground. There is no protection on these before mentioned supplies and therefore the set is still switching on but with a convergence problem.
Hope this helps.
Dawie
Oct 31, 2007 | Sony KP-57WS500 57" Rear Projection...
Vertical problems
This sounds like convergence amps not vertical, what was the set doing prior? If convergence amps first check: E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970
Sep 17, 2007 | Mitsubishi VS-45605 50" Rear Projection...
My Picture is in Red and Green??
This is a convergence problem. From your menu, go to Menu, Function, Convergence and then use you remote to try to adjust your colors. If you can not get them to line up this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Hope this help you out....
Aug 22, 2006 | Akai PT4298HD Rear Projection Television
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
