Question about Samsung SyncMaster 150MP Monitor
Power button blinks - won't turn on
I have a Samsung Syncmaster 150mp. It worked great and then one day out of the blue, it won't turn on. Let me crrect that, it turns on but nothing happens. The light under PC turns green then goes off and the power button just blinks. I've replaced the cord that runs from the pc to the monitor and it does the same thing..
    Problem Solver:
  • 18 Answers
When the power light blinks, it indicates in PC mode that there's no PC signal (depending on the monitor, it could be the sync signals or a combination of sync and video.)
You SHOULD be able to hit the source button to see if the monitor then comes up to allow you to watch another source like the S-Video, Video or TV (ok, so good luck picking up any signals if you're in the US -- but you SHOULD see static and this is probably the best "quick test" for now).
If you see static... your monitor works for most part.
Where you would troubleshoot now is the cable for your PC and the connector to the monitor on both the PC and and the monitor end. These can come loose, get abused and cause solder breaks on the circuitboards within (less common but possible).
Most cable issues I see are just bad cables from extremely tight spaces bending the cable and causing wiring breaks in the connector housings. (unrepairable because of the molded cable end)
Try those out and let me know.
-Ben
Posted on Jul 07, 2009
  • James Nov 07, 2011
    I have this same problem. Power button blinks; none of the other buttons respond, including the "source" button you mentioned in your solution above. Is there any way to get it out of "pc mode" besides the source button? Any other helps? Appreciate any help. Thanks, Jim P.S. Willing to try soldering replacement switches etc.
Samsung SyncMaster 731B Monitor blinks on and off.
It sounds like you have bad capacitors on the power supply board. The capacitors in the power supply filter the power, when they fail the power supply can not maintain operation. The blinking is caused by the power supply starting up, shutting down and restarting again. The monitor is repairable, you will need to replace the capacitors on the power supply board. 8 capacitors will need to be swapped out. Here is a link to a repair kit with the correct parts.
http://www.ccl-la.com/catalog/product_info.php?products_id=215
Apr 19, 2013 | Samsung SyncMaster 245BW Monitor
I have a doubt ...which file format support in this tv becaus.. i want to see some videos .. which.. i downloaded in youtube...
Samsung SyncMaster 150MP Monitor does not have any usb connection or built in personal video player it is only tv and pc monitor. I recomend you watch your files over a pc connected to this device. you need a device that has DIVx capability to watch video files such as .avi.
I hope this was useful..
Sep 09, 2012 | Samsung SyncMaster 150MP Monitor
Power button lights, doesnt blink, but no other buttons function, either on remote, or on monitor. I'd dealt with this by unplugging the monitor and it seemed to "reset", and the when plugged in again, the...
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 05, 2009 | Samsung SyncMaster 150MP Monitor
Samsung syncmaster 753df power button no longer works
check in back side of monitor reattch power cable after clean dust from it.
also check with other power cable that your monitor turn on with other cable.
Mar 21, 2009 | Samsung SyncMaster 753DF Monitor
Popping static noise SyncMaster 150mp
Are you still having problems with this monitor?
I posted about a "clicking" sound that has to do with failed capacitors near the speakers' amplifier IC.
If this is your problem, let me know - it can be fixed.
Check this article: http://www.benjammin.net/www/pages/techtips/Samsung-150mp.html
-Ben
Mar 16, 2009 | Samsung SyncMaster 150MP Monitor
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Blinking blue light and no display
I WOULD REMOVE REAR PANEL AND LOOK FOR A MASTER RESET BUTTON OR A BLOWN FUSE ALSO CHCEK
YOU AC ADAPTOR TO SEE IF IT IS WORKING FIRST.
Dec 06, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Clicking sound
I found the problem.
I've written up a small article on my website detailing the fix but in summary here:
Electrolytic Capacitors C826 and C835 go bad because of the heat stress applied by the audio amplifier right below them. Replacing those capacitors fixed my 150MP.
For more information see:
Jul 06, 2007 | Samsung SyncMaster 150MP Monitor
Samsung SyncMaster 150MP Monitor Logo
277 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
