Cursor only works for 5 min., then it stops.
When I turn my computer on, my cursor works good for five minutes then it stops working until I turn off the computer and turn it back on again.I've tried the dust off duster for computers I've still got the same problem.
  • mrninja
    mrninja May 11, 2010
    are you saying your having a problem with the mouse?
  • 66 Answers
There may be a mouse port problem try checking ur ps/2 port by a loopback plug.if not replace ur mouse.
Posted on Apr 19, 2009
How do I reset my computer on 2011 dodge ram
dissconect battery for a few min if that dont do it contact your local ten min oil change they will know how to do it
Mar 20, 2015 | 2011 Dodge Ram 1500
Touch screen not working
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
Automatic transmission the car drives for 5 mins and will stop if i put it off and start again it will go for another five min
I believe the problem you do have with your auto-transmission,is with the electronics,probably with ECU of the gear box. By switching off the car and restart and the gear box works for five minutes and then the same thing again from the beginning, is like by switching off you do clear and reset the program of your ECU.
It is recommended to apply to a qualified Garage for a better and safe repair.
Good Luck.
Mar 02, 2014 | 2005 Kia Picanto 1.1
Atv trouble shooting
poss overheating--carb needs rebuild--or need tune up
Jul 14, 2017 | ATVs
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
Just bought this 1999 tahoe from my brother in law and out of curosity i went through the fuse box and realized a 10amp fuse was missing from the fuse box which read security so the person that i am i put...
You need to reset the Passlock security system to your Tahoe.
1. Attempt to start the car, let it stall, but DO NOT turn the key off! Leave it in RUN.
2. Wait 10 minutes or until the Theft System light glows steady instead of blinking.
3. Do not turn the key off, but start it immediately.
4. This should reset your Passlock system.
Good luck and thank you for using Fixya.
If that does not work then your may have to do the 30 min relearn. You do basically the 10 min thing with the security light trick instructions above. Here goes this only works if your secuity light is on.
Put key in ignition don't start the car but you want to turn the key all the way on and release it back to the on position wait 10 mins or till the security light stops flashing repeat this the exact same way two more times( dont take key out) ending in about 30 mins total time. this should reset the code to the computer and you should have no more problems with it.
Nov 24, 2010 | Chevrolet Tahoe Cars & Trucks
Electric fault
You might try removing the battery connectors for five minutes and replacing back.
If the codes do not disappear, please you might have to get a scanner to do that.
Cheers.
Dec 15, 2009 | 2000 Alfa Romeo Spider
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
