Question about Mitsubishi WS-65819 TV
65 INCH PROJECTION SCREEN IS SUPER BRIGHT
MY MITSUBISHI 65 INCH PROJECTION MODEL# WS-65819 TV SCREEN IS SUPER BRIGHT WHEN I TURN IT ON. I HIT THE SIDE OF THE TV AND IT WENT AWAY FOR A WHILE THEN IT CAME BACK. NOW IT STAYS SUPER BRIGHT AT ALL TIMES. WHATS WRONG?
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Posted on Sep 19, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Super bright is due to failure in video section. 1 video supply might be absent. 2 g2 voltage mighi be high gue to some part defective at ground side. 3 chroma or jungle ic not getting supply or defective. 4 luminance section defective. BUT AS you are also saying that it came once after hitting on top so there is also possibility of loose contact also. good luck.
SOURCE:
Mitsubishi TV 65 inch rear projection. WS 65809 I went thru the convergence ic chip replacement years ago. Love the TV. My problem now is that the brightness goes from full bright to full dim then...
The old Mitsubishi units had a super capacitor in the logic circuit instead of a backup battery. This capacitor became leaky over time, causing the problem you describe among others. Number one symptom is set has audio and dark or black picture when powered up. As the super cap charges to full voltage, picture comes and goes.
Nov 27, 2014 | Televison & Video
I have a 63 inch projection tv, 8 years old, that stopped turning on last week. Not sure what's wrong with it. You can hear the power turn on inside the television though the screen does not turn on. No...
LOOKING AT THE AGE OF THE TV IT MIGHT HAVE DRY JOINTS ON PCB,S SO IF U KNOW ABOUT ELECTRONICS AND GOT SOLDERING IRON RESOLDER SUSPECTED SOLDER JOINTS AND THEN TRY.
Aug 12, 2010 | Mitsubishi Televison & Video
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
SIGNAL BOARD
Hi, Any authorized Mitsubishi dealer can order your board for you, If you live in a metro area go to Sears Service dept.(not the stores) and order one there, Mitsubishi is "proprietary parts" so you have to go to an authorized dealer, hope this helps you out, BMW Rider
Jan 14, 2008 | Mitsubishi WS-65819 TV
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65819 TV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
