SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
Yes, the main controller module can be very expensive to replace. I would take it to a reputable dealer if the battery replacement does not help.
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
SOURCE: Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
SOURCE: Our Jazzy Select G.T. power
Hi LOCKING/UNLOCKING THE VSI The VSI has a feature that enables you to lock your power chair to prevent unauthorized use. To lock the VSI: 1. With the VSI powered on, press and hold the on/off key. After one (1) second, the VSI should beep. 2. Release the on/off key. 3. Push the joystick to the full forward position until the VSI beeps. 4. Pull the joystick to the full rearward position until the VSI beeps. 5. Release the joystick. There should be a long beep. 6. The VSI is now locked. To unlock the VSI: 1. Press the on/off key and power on the VSI. The maximum speed/profile
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
indicator should ripple side to side.
Good Luck
mi mobility
