Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Discrete IR code for Current model Toshiba 32" TV
I require the discrete IR code for current model 32" Toshiba LCD TV's.
I am a crestron programmer and I need these code to do a Power On and independant Power Off commands. The original remote does not provide this code.
    Problem Solver:
  • 10 Answers
These only work on the latest models HX81 etc...
pon- 0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
pof-
0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
Posted on Jun 29, 2009
I need the wiring diagram for the 2006 chevy avalanche ignition
http://www.bbbind.com/free_tsb.html free wiring diagrams . Ignition switch or ignition system - coils , plugs , wires etc... .
Everything on your vehicle is electronically controlled by the BCM - body control module .
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the body control module (BCM). The BCM uses 3 signals from the ignition switch. These are the Ignition 0, Ignition 1, and Accessory.
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Your best bet , take it to a qualified repair shop !
May 10, 2017 | Cars & Trucks
03 grand am powers up "lights,radio,etc.turn the key nothing
Why would you do 10 minute key trick ? Is the SECURITY light on steady ? Just a code reader ? Checks just Engine PCM codes ! Need a professional type scan tool to check codes in the BCM - body control module ! Don't know what and how much you know about these GM vehicles ? The ignition switch is a low voltage input to the BCM ! To determine power mode , off ,ACC , run , crank
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 3 discreet ignition switch signals to differentiate which power mode will be sent over the Class 2 Serial Data circuit.
To determine the correct power mode the PMM uses the following circuits:
• Ignition 0
• Ignition 1 voltage
• Ignition 3 voltage
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle . If you don't know anything about this your best bet , take it to a GM dealer . Without knowing what state the BCM is in or seeing from the ignition switch or if DTC'S - diagnostic trouble codes are stored , can't give you any sound advice . Would only be guessing !
May 31, 2017 | 2003 Pontiac Grand Am
What is good video card for toshiba satellite L510? i buy it in australia. it is possible to change?
its a laptop so its impossible for you to upgrade the video card. that's the downside with laptops rather than having desktops. the only components that you can upgrade is the memory and the hard drive.
Apr 10, 2011 | Toshiba Satellite A105 Notebook
Looking for discrete codes for a Insignia NS-L55X-10A. Are there any?
No discrete codes directly. They are manufactured by LG so a lot of times LG discrete codes will work.
YMMV.
Mar 01, 2011 | Insignia Televison & Video
I would like at published discrete code list for a Samsung UN55C800XF TV to program into my Universal Remote MX-700.
Hi.
Your TV is an LCD TV, I do not know if discrete codes are different from ones published for previous model. Codes for this specific model are not yet available on the web, but codes for previous model will probably work (see here).
Codes:
HDTV Televisions (4)
HLN Series HDTVs (14)
HLP Series HDTVs (14)
HLR Series HDTVs (9)
HLS Series HDTVs (21)
HLT Series HDTVs (21)
Have also a look at this thread.
Jul 26, 2010 | Televison & Video
I would like to set the clock on my sanyo 32
The easiest way is some sort of automation system like Crestron or RTI with an astronomical clock and IR capabilities.
You could easily add a timer to the outlet but that will only take the TV from all off to standby. To turn it on you have to send the IR command for power. Also, I doubt the Sanyo has discrete codes for power which will make this impossible to make reliable because if the TV is on at the time you have the automatic power ON it will turn the TV off.
If you really have to do this, here are the parts:
RTI XP8 RTI VS1 Niles MF1 Programming software and a programmer
Nov 24, 2009 | Sanyo DP32648 32 in. LCD TV
Unable to detect lcd
Replace the Discrete Video card. That's why your LCD didn't detect when you run the Diagnostic test. There 2 type of video cards available to Dell Inspiron 6400/E1505. Either you have a on-board video card or discrete video card. Mostly, the discrete video card is caused when you not getting video output to your LCD (completely dark as if it is off). Discrete video card is detachable and replaceable. Good Luck.
May 16, 2009 | Dell Inspiron 6400 Notebook
ILive IT188B - Not a problem, but a question as I have not purchased the unit yet. I am looking to enhance the sound from my Digital TV. The chances of ever using an IPod are slim. My question; can it be...
Yes, absolutely. It has inputs from which you can connect your TV. Its a nice box for the price. The remote SUCKS! Terrible key placement. However, you should be able to program the remote into another universal remote. Although, I have not figured out how to do that yet as ilive does NOT posts discrete IR codes or hex codes for the more advanced programmers.
Feb 24, 2009 | GPX MW3837 MP3 Player
RCA remote with an APEX TV
What is the model number of your TV and remote control? With out that information it's hard for us to figure out the discrete codes you need in order to program everything to operate.
Otherwise you can always quickly notify the manufacturers customer service over the phone what products you own and they can offer you the discrete codes over the phone for your convince as well. Some people find that easy in case you do not know where to find your product model number.
Keep us posted!
May 26, 2008 | RCA RCR311B Remote Control
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
1,004 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
