Question about AOC LM929 (Black) 19" LCD Monitor
Power Monitor is only a year old and the power just suddenly went out. I tried it on another computer with no luck. It is just dead. Any suggestions?
  • lilstinker Sep 18, 2007
    It is an AOC 19" LCD LM929 model
  • Matt Falcon
    Matt Falcon Apr 16, 2008
    Picked up a LM929 that also has a similar power problem, but it's lasted longer (about 3 years, so they say).
    The fuse on the power control board was totally shot. Thinking it was the result of a surge or some other anomaly, I tested it (probably not the best way) by shorting the fuse. That resulted in a releasing of the magic smoke and a small light show. I blew a trace on the power PCB.
    After I brought the monitor home, I tore it apart and took my multimeter to it. The transistor mounted on the single heatsink (not the one with two transistors mounted to it) was fully shorted, 0 ohms all around. I did some research on that chip and found that, while it's out of production, it should be replaceable with:http://www.mouser.com/Search/ProductDeta... - a STF9NK60ZD. I have two on order in case I foul up the first one.
    Meanwhile, I searched around and yanked a similar (but far out of spec and way too cheesy to work properly) MOSFET chip from a dead PC power supply I had laying around. I soldered that into place and gave it a try. Well, no more earth-shattering kaboom (actually, it now gives the typical "snap"), but it still doesn't work. I think the chip is putting out the wrong levels to work properly. I'll have to wait for the new chip to come in to see if that fixed it.
    I also found a couple bloated capacitors on the board - maybe AOC is using cheap **** capacitors that may be to blame for other problems...
    Problem Solver:
  • 5 Answers
Check the power pack to see if it has the required output voltage, usually 12-15 volts. solidstate power packs are prone to failure. The LCD screens require between 2 and 4 amps to power them. A strain on some power packs. Gary(Honkity Hank)
Posted on Sep 18, 2007
SOURCE:
My samsung syncmaster 740n take almost 1 hr. to display after start it.
a monitor that is, its is not a computers.
so is it dead, even not VGA/DVI plugged in to a PC>
power on monitor
all monitors the sign on (with Samsung logo)
tnen tell you
NO SYNC, no SIG, or not signal, due to the cable is not plugged in
if you can push menu key 1second after turn on and that OSD screen is dead, that is a bad monitor if it is dead.
i see its old, VGA only. tell s me that.
as does model #
square screen relic.
i think this monitor is 18 years old
and us CCFL monitors, 10 year later we went to LED backlamps
yours is not LED, and has CCLF lamps that go
DIM
dead,
blink
or intermittant
or take hours to come on.
time to retire, i because fixing it is more that new cost of a good monitor, buy one say used made in 2011, and get LED.
advance by 10 years, and win.
Jul 24, 2018 | Samsung Computers & Internet
Dell 1800fp dead
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Nov 26, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Hello, I have a samsung 943nw PC monitor and all of a sudden the screen went off and the power light went off also. I have tried connecting it to a different power source but still not working. I thought...
If the monitor is completely dead, then is sounds like the power supply board has failed. Sometimes it an easy fix, by replacing a fuse. Most LCD monitors do hav a fuse, the only way to know for sure is to open the case and troubleshoot the power supply.
May 16, 2011 | Samsung 943NW Monitor
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
Feb 14, 2018 | HP W19b LCD Monitor
No power - suddenly went dead, no green or orange power light.There is mains power at the monitor's power input socket.
Check all caps in power supply. Look for the tops of the caps to bulge. Replace any that looks or smell bad, like a sulfur smell. Make sure you put them in the right way. I usually increase a cap that blows. If its a 16v I go to a 25v or a 25v to 35v. keeping the same ufd. Because of the surge, off and on, It helps.
Oct 26, 2009 | ViewSonic VX924 19" LCD Monitor
Monitor not working
It may well be dead. Try testing the monitor on another working PC. Also try a working monitor on the problem PC. Then you will know whether it's the monitor or the PC graphics card that's faulty.
Jan 09, 2009 | Dell Dimension 2400 PC Desktop
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
jonno
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
Open Questions:
See all AOC LM929 (Black) 19" LCD Monitor Questions
AOC LM929 (Black) 19" LCD Monitor Logo
207 people viewed this question
Top AOC Computers & Internet Experts
Ekse
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
