Question about Car Audio & Video
Clarion drb3475 speakers not working
We just installed a clarion drb3475 cd player into my husband's 98 Jeep Wrangler. There is power to the radio and cd player but no sound at all through the speakers. Not even popping or buzzing. Do we need a different wattage speaker than the factory ones?
  • tomboy430 May 02, 2009
    need to wire speakers have not got schematic drawing of wires
SOURCE: Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Posted on Jul 09, 2007
THENTHEREWER
  • 131 Answers
SOURCE: 2000 mitsubishi lancer radio not working
check the jack in the back of the stereo,it may not be seated all the way.hope this helps.otherwise you may have an internal problem with the unit itself.
Posted on Nov 16, 2008
djlegion
  • 8 Answers
SOURCE: radio shows on but no sound to speakers
I flooded my Eclipse and the AMP is under the passenger seat. Might have got wet and ruined it. They are expensive from the dealership ($900). Try a junk yard.
Posted on Nov 17, 2008
SOURCE: Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Posted on Dec 02, 2008
  • 6 Answers
SOURCE: trying to hook up aftermarket radio 98 windstar limited.
If this model has an amplified system, then you may need a different wiring harness. The harness you purchased may be for the non amplified model. Try that, and let us know.
Posted on Jan 29, 2009
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
Need to install cd player in 97 wrangler. need to know which wires are speaker ground power etc.
easiest thing to do is to go to best buy and buy a radio harness kit for $15-20 which will plug ontop of your radio harness so you don't have to splice any wires. the kit is a plug on one end and labeed wires on the other end that will tell you where everything you need is to install a new cd player in such as your power, ground, remote, and speaker wires...much easier to do then to splice and trace each wire.
Jul 11, 2009 | Wrangler Jeep Twin Stroller
Just installed my dxz385usb. powered up and got
Check to make sure that the speaker negative and positive leads are not touching. I had the same issue on a 97 maxima, and found the rear speakers so damaged that the (bare) leads on the speaker itself were touching the basket of the speaker, shorting the whole thing out. I disconnected the rear speakers and it started working.
Jul 04, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Nov 09, 2008 | Clarion DB538RMP CD Player
Installing my radio
You can download the manual for installation and operation from the following link: http://www.clarion.com/us/en/products/2006/audio/source_units/cd/DXZ865MP/us-en-product-pf_1134643389122.html Please update the question & let us know if the information was useful for you - good luck!
Aug 22, 2007 | Clarion DXZ865MP CD Player
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Car Audio & Video Logo
95 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
