Question about Sony CDX-GT210 CD Player
No sound from cd player
Ok, the cd player kept cutting out so found a way to fix that but now there is no sound coming from it. the radio produces sound but thats it.
It may be the cords from behind the panel that have come loose or that the cd playing unit itself if gone. If you know how to, take out the head unit and disconnect and reconnect the cables/ cords the unit and see if that helps at all...because of rough road/ driving it could have loosened them enough just to cut out certain things on the unit. Hope this helped liljman1213
Posted on Sep 19, 2007
SOURCE:
Radio and CD-6 player
The humming sound prior to cutting out could indicate a short in the unit itself.....remove unit and have it tested!
Aug 21, 2015 | 2003 Ford F-150
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
No soung rsdio 02 fiesta
switch some where in radio cut off its auto for cd, but stuck ofen or maybe a transistor switch, well good luck. Some of those toyaota radios are full of querks.
Jan 16, 2014 | Toyota Corolla Cars & Trucks
Radio intermittent
you have a bad connection between head unit and rear window
Nov 21, 2013 | 2008 Audi TT Coupe
No sound on am or fm only static but sound with cd player
check the antenna connection. you may have to open up the radio to fix the problem, and may require soldering. I recomend butane powered soldering gun since it produce no stray current like an eletric soldering gun.
Nov 23, 2009 | Bose Wave Radio
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
Sony cdx-gt300 AM radio malfunctioning
If no AM and everything else is ok , the unit needs to come ouit for repair...keep in mind that these are cheaper to replace than repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 11, 2009 | Sony CDX-GT300 CD Player
Assorted dash board lights
If you smoke or eat in your vehical your smoke proble got in to it and messed up your hloe system. I suggest you getting a cd/dvd cleaner and try that. If it worked for me it should work for you to! Good Luck!
Sep 13, 2008 | 2000 Volkswagen Beetle
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
[email protected]
Jan 12, 2008 | JVC KD-S890 CD Player
CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Oct 11, 2007 | Panasonic CQ-C1303U CD Player
Sony CDX-GT210 CD Player Logo
102 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
