Question about Medion M3 Composer 5100 PC Desktop
Computer wont start.
Turn off computer, unplug wire, wait 15 min, plug wire back in, wait another 10 min, press the button and it doesnt turn on. Help?
  • crims111 Sep 18, 2007
    Nothing, thats the idea. Other times i did that my computer would wait like 5-10 min to suposedly "power up" but now its just not turning on... at all.
  • Dennis2 Nov 13, 2007
    I have a Medion model 8314b. The start button just flashes blue and will not turn on the computer. The fan runs. Turn off the power (in back of computer). Fan goes off and so does flicking light. Turn the power back on fan comes back on and so does flicking light. It's like it is always in sleep mode. I've unplugged it etc. it still does not work. It just will not wake up. Any idea. I have to print out some invoices in the morning and need this computer working could you e-mail me ASAP [email protected] thanks
    Dennis
  • 24 Answers
What happen if not waiting for 10/15 minutes... a bit details will help the support.
Posted on Sep 18, 2007
SOURCE:
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Msi ms-7184 ati rs482 socket 939 motherboard stuck on hp invent
Hello Sammy, try pressing and holding the power button to turn off the computer. Unplug the computer from the wall and wait 10-15 sec. Plug it back in and power it on. See if that works.
Dec 30, 2013 | Computers & Internet
My sony vaio eb (e series) wont turn on, the power button flashes green! PLEASE HELP!
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Sep 24, 2012 | Sony VAIO EB Series White Notebook...
I put my acer aspire in sleep mode and now it doesnt turn on
Hi marvmom,
Have you tried draining the power of your computer? The easiest way to resolve this issue is by performing a power drain. Please follow the steps below.
1. Turn of your computer completely by pressing the power button for about 10 seconds.
2. Now, unplug the AC adapter from the power outlet.
3. Remove the battery from the system.
4. Press the power button for at least 15-20 seconds.
5. Put the battery back inside the system and plug the AC adapter.
6. Try to reboot and observe the computer.
Hope it helps.
Thank you for using FixYa.
May 11, 2011 | Acer Aspire One PC Notebook
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
This should work....all the best
May 19, 2010 | Computers & Internet
HP desktop computer will not load...
what os you are loading?
did you purchased it with bundled os/softwares?
Apr 01, 2008 | Computers & Internet
Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective.
Sep 18, 2007 | Acer Aspire L100 PC Desktop
Computer won't start up!
Waiting for 10 or 15 or even 30 minutes doesn't make much sense to me. What kind of flash drive or drives do you use? .. USB Thumb/Pen/Flash drive? .. If your flash drives in "My Computer" folder just happen to disappear, does the computer still working or freezed state? When you say your computer does not want to start on AT ALL.' the machine is not running at all or just that the operating system is not booting up?
Sep 18, 2007 | Medion M3 Director 5100 PC Desktop
Medion M3 Composer 5100 PC Desktop Logo
189 people viewed this question
Top Medion Computers & Internet Experts
Ekse
Hollyecho Montgomery
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
