Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
How do i get digital channels on my tv
I have a WD-52327 tv and would like to know if i need to use a convertor box to get the new digital stations and if No then how do i do it
  • Anonymous May 01, 2009
    how do i get digital chanels on my new tv
Get freeview or sky or something like that.
Posted on Apr 18, 2009
Mitusbishi WD-52327 tv cannot figure out how to get the digital cable box to come on screen?
Connect RCA wires (yellow, red, white) from the box's "out" to the tv's Input 1 or 2 on the back input panel of the tv set. If you don't have RCA's you may use a RGA- jumper wire (cable wire made into a 4 ft segment by the tech or buy a short cable wire from the Walmart, Target, or Goodwill store) Connect this wire to the "cable in" on the tv and the other end to the "cable out" on the box.ADDITIONALLY make sure you have the right input settings selected on the tv with the input selection you make with the wire connection you choose.
Jun 21, 2012 | Mitsubishi WD-52327 52" Rear Projection...
What do ineed to watch this tv now that we have digital services
Yes you do. Not only do you need a convertor box but an antenna to connect to the convertor box. The convertor box will have to be plugged in and depending on the antenna it might have to be plugged in. This tv does allow and external antenna to be connected to it. This is where you will attach the convertor box with whatever adaptor you may need. The tv will need to remain on channel 3 at all times.
May 05, 2010 | Coby CX-TV1 5 in. Portable Television
Quite cable a month ago. have had 12 channels
I would contact your cable provider. They might switch things over to there digital side, and it will have to take a digital box to get them.
Oct 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Convertor box is hooked up but says no signal please describe how to hook up to make sure it is done correctly
I'm thinking that the particular channel it is on has no signal, and that it's your TV is not getting a signal from the converter. Ignore it, and do the scan that the instructions call for. The scan will land on enough channels that do have signals and once you tune to one of those you'll be ok. Once you're set up, you'll find that stations that are normally on air just aren't from time to time. Just skip over those until things settle down later. You can always delete those stations if you didn't want them anyway, and there are new stations that are not fully operational yet. Rescan every couple of weeks,you'll find new channels being added from time to time.
Jul 08, 2009 | Insignia Digital-to-Analog Converter for...
I have a wd-60735 tv if i hook up a convertor box to it i get air channles if i just hook up the antenna to it it wont find any channells what could be the problem? Thanks
As of 6/12/09, the over-air broadcast signals went to digital (ATSC) only. Your set does not have and ATSC tuner so it can not receive the new digital signals. The converter box converts the ATSC signals to the NTSC channel 3 or 4.
Dan
Jun 19, 2009 | Mitsubishi WD-60735 Projection Television
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Do I Need A Convertor Box?
No, your television has a digital tuner built in. You will not need a converter box. When the switch to digital is made, simply use the auto scan feature to program all of the new channel locations. Instructions found in the manual here - http://www.p4c.philips.com/files/2/26pf5321d_37/26pf5321d_37_dfu_aen.pdf
Dec 27, 2008 | Philips TV Tuner Video Capture PCI Card -...
Need to know if my tv is digital or analog?
most new tv's are digital capable...
but here is the trick the convertor box are only for those who don't have cable or satellite service if you use only an antenna to get channels then yes you will need a converter box for each tv that uses only the antenna to get channels if you have satellite or cable service then they don't need a converter box even if they have basic cable they won't need the box there channels are already digital converting now there are a few events that was in anlog but there are being converted as best as possible but you may notice the difference in the pictures betwwen analog (usaully old time movies or show even commercials) Digital (most everything now that are new stuff are digital and even in hd now)...
Nov 12, 2008 | Televison & Video
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
WD-52327 Red Light Problem
Try pushing input and menu buttons in together on the front TV panel and hold in for 8 seconds to see if the set blinks a two digit code as it may have bad capacitors if it blinks a 3 4 code.
Jun 05, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
