Reduce power engin and serves engine soon come on..Reduce power engin and serves engine soon come on..
AnonymousMar 13, 2014
Whould not accelerate.Whould not accelerate.
AnonymousMar 24, 2014
when you get ready to go when on and you try to go it will act like it is pulling a anchor then when it reaches about 3000 rpm it will accl.fast and reduced power light will go off. it might or not come back on the next time you stopwhen you get ready to go when on and you try to go it will act like it is pulling a anchor then when it reaches about 3000 rpm it will accl.fast and reduced power light will go off. it might or not come back on the next time you stop
You can't post conmments that contain an email address.
the "brain" of the car has detected a problem and is reducing the power available (limp home mode), get it to a garage and have them scan the odb2 data (or get a odb2 scanner and do it yourself. it will provide a fault code) the fault code will tell why it went to reduced power mode (limp home) Isuzu OBD II Trouble Codes
That has happened to me before. I parked the truck, turned off the engine, waited for about 5-10 and restarted. As long as the reduced speed indicator and/or the check engine light don't remain on you are good to go...hope this helps
Try adding gas line antifreeze to your fuel. If you have water in the gas, this will clear it up. Water in the gas line can turn to slush or even ice when the temperature dips below freezing, causing reduced power because of reduced fuel flow.
I tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for
forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
all electrical power must come from an alternator an a good batterie to store it please ck your alternator or have it ck by an parts store clerk if the altrenator is bad (must develop 13 0r 14.5 volts output. anyting above that ,the alt is bad!) change it then ck your batterie an batterie connections terminals and all the 80 amp fuses on the fuses box nicolas
I just went through this with my 2001 rodeo and the dealer needed to replace several parts over several weeks because they could not get the problem to go away.
-APP/throttle pos. sensor needs calibration/replacement
-air idle control needs replacing
-throttle body needs replacement
After months of going back and forth to the deal with the same problem, the throttle body was replaced last week and the problem has dissapeared....for now...
