Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Time and Temperature Projection problem
Hi, I have porblem with projecting time and temperature. The digits are shown not full, some elements are missing on each digit. Any idea how to fix this problem.
  • shielad Feb 09, 2008
    I just brought home the Homedics Sound Spa Premier SS-5000 Clock Radio and have the same problem. I am showing all 8's, as if there was a decal hidden somewhere. The rest of the clock works fine. I cannot understand how the projection feature can be messed up, unless it is reading the time from a different clock (internal). It just doesn't make sense.
Mine's done this before as well.
I usually have to unplug the power from the back of it for a second and plug it back in. I've found no reason why this happens though.
Make sure you have the backup batteries in it when you unplug it.
Posted on Mar 11, 2009
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Setting the time on ascot projection alarm clock
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Mar 31, 2012 | Audio Players & Recorders
The temperature light on my tv is red and keeps turning off
If its been more than 2 years since you replaced the lamp, might be time for a new one. check the lamp code on the side sticker, should be # BP96-00224J. Good luck.
Nov 26, 2011 | Samsung HLN5065W 50" Rear Projection...
Panasonic 56" HDTV Projection TV. Model PT-51HX42 TV power button flashes 3 times and then turns off
You have a defective temperature sensor
3 blinks flashes oncenevery 5 seconds
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic PT-51HX42 51" Rear Projection...
When there has been moisture this car will not start
spray in side of distributor with silicone lube also coat plugs and wires
Sep 20, 2009 | 1993 Mitsubishi Mirage
Remote signal not received by Shift 3 projection alarm clock
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
Aug 02, 2009 | La Crosse Projection Alarm Clock with...
Picture porblem
bad light engine. send to PTScorp.com for rebuild. new or rebuilds cost $800.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
631 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
