Question about Sony Playstation 3 (PS3) Console
Boot problem while booting system is hanging..,
  • pelicans405
    pelicans405 Nov 21, 2008
    The PS3 has worked for years and suddenly stopped booting.  It may have occurred last week when it came on in the middle of the night (bumped a wireless controller) and then it got shut-off during the startup (TV was off, so we had know idea what stage it was at).
    It used to come up to the black background screen and there was the "spinny" icon in the upper right corner.  Now it does not even do that.
    I don't have a USB keyboard -- if I go buy one will I be able to fix or will it still have to go back to Sony repair???
    Problem Solver:
  • 11 Answers
I don't want to say the above suggestion wasn't helpful, but it didn't work for me. I borrowed a USB keyboard and I tried your suggestion. I even built a Linux boot disk (from another google search) but it just did not want to boot from any media. I know the boot disk was properly built since it booted in my other desktop CPU.
I paid Sony the $149 ransom and it is now working.
I don't really want to label this the solution and skew the stats, but it was for me.
Posted on Apr 29, 2009
    Scholar:
  • 57 Answers
This is an issue Sony is aware of and is posting updates to the linux program. However here is a step you can do right now. Updating your PS3 to the latest firmware is recommended before proceeding To force the PS3 to boot up normally hold down the Power button for about 5 seconds or more at power on. This is in case you do not have a keyboard. with a keyboard you can use boot-game-os command to reboot to the PS3 game os: If you have the media cd attempt this also Select Settings -> System Settings -> Format Drive. Note that you will loose any saved game info. Create two partitions one for the PS3s normal use and one for openSUSE. Insert the media in the PS3 Select Settings -> System Settings -> Install Other OS. The PS3 will display the installers it can find. Click OK to start the installer. Follow the instructions of the Sony installer. To boot into the Other OS, select Settings > System Settings > Default System > Other OS. This causes the 'Other OS Boot loader' to be loaded on every boot. .
Posted on Sep 19, 2007
I have a compaq presario 5600 / P4-1.5G/128MB/40GB/C48/M The other day the system hung, and nothing was working. I changed the CPU battery, cleaned the dust. the system started with Intel boot agent 4.0...
You probably need to set your boot order in BIOS (setup) to load from CD first. Reboot the computer and press either F1 or F10 repeatedly until the setup (BIOS) menu comes up, then, using your arrow keys, navigate to the boot menu and set the boot order to CD first.
If you can't get into the BIOS through F1 or F10, try other "F' keys until you get in. Also the "Del" key.
Recovering to factory settings is kind of a drastic measure just because of a system hang. You would be better served to find out why the system hung. IN FACT, understand that depending upon what is wrong, the system may hang during the recovery, leaving you with fewer options for repair.
Post back if you want to try to troubleshoot this further. It will take a while, but we should eventually be able to determine what is causing the hang.
It could be just an application that needs to be removed or re-installed. Have you installed any new software recently? What software were you using when the hang occured? What operating system are you using?
It could just be a virus or a bad memory module. Are you able to boot into SAFE MODE" (press the F8 at boot)?
If you can boot into Windows, go to "Start" > "Control Panel" > "Administrative Tools" > "Event Viewer" > "System" and check for any error entries. Also look at the "Applications" log.
Aug 15, 2010 | HP Compaq Presario PC Desktop
Pc hanging
Scan your PC with a good antivirus like avast which support boot scan;it will solve your problem if it is caused virus,worm or malware.
Sometimes system hangs when a porgram start to load during bootup too.
for troubleshooting this,boot your system in sfae mode during startup by pressing F8.Click "start" then "Run" type "msconfig" select "startup" tab untick all the program and restart your system.
PC hangs or reboots due to overheating of the CPU.It is caused by dust and dirt contamination inside.open the system and blow it with a small air blower.
Dec 18, 2009 | Acer Aspire One PC Notebook
If i enable the USB drive in CMOS.after booting the system is hanged.only mother board name mercury is shown.
The problem is with the Installed USB Devices. Check whether you are using any of the USB slots in your system. If any printers or any other USB devices are installed the boot will check with these devices, so your system is getting hanged. Try to disable the USB booting or else remove the usb device and then boot. This will resolve your problem.
Oct 19, 2009 | Mercury P4VM800M7 Motherboard
Laptop sometimes take long to boot, cursor hangs after booting
well if u use internet on your laptop,i wold sujjst you to keep deleteing cookies from the internet web page,from tools,again perform this step
click start>all programs>accessories>system tools>disk clean up/disk defragmentation.....it shoud work for u.....
Aug 25, 2009 | HP Compaq nc6220 Notebook
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
After water spillage system is not able to boot completely its getting hanged in between, tried to boot through net, usb cdrom the same result , pl help
Good morning! Possible that some internal part/s of your Acer One computer might be damaged, I suggest to bring it to an Authorized Acer Service Center for proper hardware parts check-up & repair. best regards
May 08, 2009 | Computers & Internet
My computer hangs when i boot it by any bootable cd or floppy
Apparently you solved your problem and the system no longer hangs, though you never supplied the information requested.
Apr 07, 2009 | Soltek X400A (SL-85ERV2-L) Motherboard
Hi I have Sony VAIO VGN NS135 laptop on which I have installed Windows Vista Ultimate Now there is error in booting and showing these lines Booting 'Windows Vista' acpi Vista Loader 2.1.2 Done! fallback 1...
This means that the operating systems was not installed properly...."Boot manager is failed... and ntldr is the main file... which help computer to boot up..." try reinstalling the operating system again...
Jan 12, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
Bios hangs
Reseat all cards in system, including the RAM. If it still does not boot try removing one stick of ram at a time to see if it boots. As well as removing extra cards.
Jan 05, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
T40 hangs after boot up. Sometimes does not show anything on boot
it may be because of the cpu cooler is so full of dust that the fan cant go around and the cpu gets hot and the whole system freezes or something else is totaly screwed up
Jan 04, 2009 | IBM ThinkPad T40 2373 Notebook
Sony Playstation 3 (PS3) Console Logo
1,120 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
