Question about HP Color LaserJet 2600n Printer
Paper is jamming when I print something
I was attempting to print business cards and my printer jammed when it attempted to print on the reverse side. Now all of my printouts jammed into an accordian fan fold. How do I correct the jamming? Thanks!
  • jordon825 Apr 19, 2009
    Now I get the message 'Jam in output tray' and I can't see anything causing a jam.
    Thank you Worcesterlad for responding.
  • 44 Answers
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Posted on Apr 18, 2009
I had a paper jam, removed paper and now when I attempt to print, I got mssage saying printer is busy
go into were it is saying printer is busy and cancel any work waiting to be printed..but before you do that unplug your printer the plug back in some times this will re,set your printer.
Nov 05, 2016 | PRINTER Office Equipment & Supplies
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Had paper jam, took several attempts to clear. I now cannot get my printer to power up?
Issue On Paper Tray... also reset you spool Tray Memory System ..Unplug Printer from PC tun off Printer ..Open Back Cover then clean Paper Jam Then Re plug printer then turn it On ...Then Try to Print Something
Oct 07, 2010 | Epson Stylus CX9400 Photo Printer
I have an HP C7280 All-in-one printer. I was
Well, I took the printer apart(as much as I could w/o removing any screws)and copied something onto card stock. I was looking for any extra business cards that I'd missed. The copying worked. I then unplugged everything and took the printer off of it's stand. I then noticed a piece of plastic from the feed in the back lying on the stand. I somehow managed to get it back on the printer where it belonged and voila! the printer worked! Don't know if the plastic piece was the culprit, but at least the printer works now.
Oct 02, 2009 | HP Photosmart C7280 Laser Printer
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Paper jam, so small, can't even see paper
first off, unless you know that the paper is there, it's a possibility your machine is just saying or acting as if there is a jam when actually there is something giving a false reading or a failed part rendering it unable to print. Otherwise, if you happen to know where there paper is jammed at, attempt forcing a heavier stock paper through. say the jam is between two rollers attempt pushing a cardstock or index card thickness of stock through the rollers to attempt pushing the paper backward which might either remove the jam and make it removeable elsewhere, or make it so the machine can try to feed the paper through again this time allowing you to reach it.
Oct 28, 2008 | HP Computers & Internet
HP 6180 printer
henryandjane,
Look over on the wheel that will feed the paper mybe there is a tiny piece of paper on it and find the sensor for the paper mybe it is stack-up already
Jul 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
MP600 Paper Jam
I just had the same problem, tried everything and resigned myself to buying a new one. I was about to throw the thing when I saw the Card backing of an A4 Pad. I thought I have nothing to lose so forced this through the machine and Bingo. It cured it.
Jan 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam on 1 side
at start paper jumps in gear pulls to one side
Sep 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
221 people viewed this question
Seeker5211
Seeker5211
