I'm trying to connect my viewsonic vx715 lcd monitor to my boyfriends tower but when i connect it, it says there's still no signal. what am i doing wrong?
  • krista426 Apr 18, 2009
    there are no pins missing on the monitor cables, i've checked.
    there are 2 video outputs on the back, i've tried both and i don't know what model it is, this is my boyfriend's computer and it's custom made
  • Spradlike May 11, 2010
    How many outputs for video are on the back of the computer? What computer model is it?
  • 102 Answers
Make sure there are no pins missing on the monitor cable
Posted on Apr 18, 2009
My vx715 monitor is stuck on standby
try to adjust its resolution to 1280 x 1024 or less
if you see that is helpful please don't forget to vote me
best regards
Apr 24, 2011 | ViewSonic VX715 17" LCD Monitor
Monitor shuts off
Is the monitor light turning off, indicating the monitor is turning off? Or is the monitor/computer going to sleep?
How do you get the monitor to turn back on?
Verify the power cord is securely plugged into both the monitor and the outlet.
Try a different outlet.
Mar 12, 2011 | ViewSonic VX715 17" LCD Monitor
Have just upgraded to windows 7 and my Viewsonic vx715 is only recognised as a generic PnP monitor and I can't load drivers from disc supplied. monitor is approx 6yrs old and still going fine!
In most cases you don't need the drivers for a monitor to work completely fine. In order to obtain your drivers you can always check the manufacturers website and they should have drivers listed, in your case they do. Although I couldn't locate VX715 i found many VX models in the driver search. There should be one that works fine, just make sure you download the right right IE: windows 7 x32/86 if your running a 32-bit operating system, or windows 7 x64 if you are running a 64 bit operating system. Here is the website I located http://www.viewsonic.com/support/downloads/drivers/
Jan 09, 2011 | ViewSonic VX715 17" LCD Monitor
My View Sonic VX715 LCD sometimes will come on with the top of the screen darker and it will lighten up towards the bottom then go completely dark. I found buy tapping on the top of monitor it will come...
fixing a LCD monitor require you to have some basic electronic know how.. changing the backlight won't be easy as you need to dismantle the whole LCD right to the screen..
But if the display only lasted for few minutes and then the whole screen turn dark, this is due to bad component on the board.. most probably capacitor...
May 24, 2010 | ViewSonic VX715 17" LCD Monitor
White line near top of the screen on a viewsonic vx715 lcd monitor.the line is aprox 0.5cm thick
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Mar 09, 2010 | ViewSonic VX910 19" LCD Monitor
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Viewsonic vx 715 the monitor turns off after 10secs through both vga and other cables on different pcs - the screen goes blank - when you turn the monitor off and on again the same thing happens - any...
Your monitor is probably shuttin off once something is heating up enough to cause the safety relay in its power supply board to shut it off. I find that once a monitor goes, just toss it, it isn't cost effective to try and have it repaired the
cost will exceed the cost of a new monitor
Sep 13, 2009 | ViewSonic VX715 17" LCD Monitor
Viewsonic vx715 17" lcd turns on but goes dark in like 5 seconds
You need to replace your Inverter board or replace the 2 black caps on the power supply board wich are labeled 1000uF 16v ELITE. that will cure your problem. Glad I Could Help!
Apr 08, 2009 | ViewSonic VX715 17" LCD Monitor
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
