Question about Salter 2001 electronic kitchen scale
Have been given Salter Aquatronic 1030 scales but no instructions - how do they work?
  • Anonymous May 16, 2009
    Need copy of instructions
  • Anonymous Mar 29, 2014
    how to change battery
Hope this helps.ChrisHave been given Salter Aquatronic 1030 scales but - 666856f.jpg60f78a0.jpg
Posted on May 12, 2009
My Salter model 3003 kitchen scale shows Err when I turn it on. How can I fix this?
This means that it cannot calibrate itself because the sensor is out of range. This can happen if you drop it or overload it. Check the feet on each of the for corners and make sure they are not stuck, you can do this with the unit on and see if it registers any force on the pads when you press and release them or use a screw driver to lift them SLIGHTLY. There are a lot of youtube videos on how to check and repair them.
Jul 30, 2016 | Salter 3003 Aquatronic Glass Electronic...
Is my scale calibrated. When I turn it on it first shows 8888 7/8, then it 0/0g
Take a ten pound bag of sugar and calibrate the scale to read 10 pounds.
Oct 30, 2014 | Salter 3007 Aquatronic Digital Scale
Salter scales
Maybe the battery needs replacing its what happened with mine I replaced battery and its been working fine ever since.? 1 CR2032 lithium battery .
Jan 25, 2014 | Health & Beauty
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
I have taken the back off my bathroom scales as they stopped working and as I did i pulled a few of the wires off, not sure now how to re attach them and to where is there anywhere that you can get...
mcdevito75 here, Chances are the digital portion is burnt out, You can try an appliace repair shop in your area, I don"t think you"ll be able to get the wire schematic, you can also try to call the manfacturer or vist online. Sorry!
Jun 30, 2010 | Salter 3007 Aquatronic Digital Scale
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
Apr 01, 2010 | Salter 3007 Aquatronic Digital Scale
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
Salter 2001 electronic kitchen scale Logo
1,285 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
