Question about Sherwood RX-4109
When the power is swithed on as soon as the tuner or auxillary kicks in the power shuts off.
When i switch the power on as soon as the radio or ausillary kicks in the power shuts back off.
    Genius:
  • 1,148 Answers
TAKE THE TOP OFF ,,AND BLOW IT OUT
Posted on May 15, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
1991 suzuki gaxr 1100 shuts off when place into gear
Only thought Is the Kick stand switch
Is a kickstand on or was there one ever on this bike? If the switch thinks the kickstand is down it will stall out as soon as you kick it into gear.
Jul 27, 2013 | Motorcycles
Radio wont turn on.
You have a power wire going to your on off switch you should also have a power going to a memory wire to keep your stations and clock intact.
Apr 21, 2013 | 1997 Toyota Camry
Does brake light switch affect cruise control?
Yes. The brake light switch has to be in good condition because it is one way to disable the cruise when driving.
Jul 24, 2012 | 2004 Chevrolet Malibu
Hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Apr 25, 2012 | Sony Audio Players & Recorders
Tuner stch7 shuts off automaticly and the radio does not play - what should I do ? Brand - Panasonic Model stch7 Power shut off and when you try to put the tuner back on it Keeps shutting off....
We have a similar problem, panasonic st-ch7 tuner, otherwise seems ok but only get static, like the aerial is absent. cd etc fineThere is a little "E" flashing not sure what that is
Sep 11, 2011 | Panasonic Audio Players & Recorders
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
02 altima wiring for all three harnesses
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | Car Audio & Video
I have a Phillips big screen tv and the front light is flashing red at all times and the picture will not come on the screen. This light is usually green when the set is on. What can I do to get it green...
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Aug 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Sherwood RX-4109 Logo
776 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
