Question about Kitchen Appliances - Others
Not making ice water reservoir have a broken
Not making ice water reservoir have a broken platic where gear motor seat need part new reservoir to fit it where to get part greenway ice maker model gim15p-2
  • Gintautas Maldzius
    Gintautas Maldzius May 11, 2010
    Is this a correct category to post your thread?
aborcass
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Coldspot Ice Maker Gear Broken
best bet os to order and replace the entire assy, the gear broke due to an over torquing problem that they fix with a kit that ioncludes a new module and a new stripper bar, the labor involved and chance of breakin more parts make the entire assy a more feasable way to go, you can proble find a repacemnt online for undder $75
Posted on Feb 16, 2009
  • 136 Answers
SOURCE: ice maker is not making ice...no water to tray
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Posted on Jul 07, 2009
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
Water is not pumping up to the reservoir. If i manually put water in the reservoir it will make ice.
I just had the same trouble after connecting it to my new filtration system. Yes, if you pour water in with a funnel, it will make ice. You need to be wary of overflowing, as it will drip into the ice reservoir, so close the door quickly so overflow will come out the ice dispenser.
Oct 22, 2015 | ULINE U-Line 2000 Series U-CLR2160S-01
My Scotsman CE33A cycles on and fills with water then within 3 r 4 minutes the water volume goes down and wont spray up into mold.i can fill the resivor with water and it does fine until the water lev
In the water reservoir there is a tube that maintains the water height during operation. It fits in the overflow drain hole and keeps the water level at the proper level. This tube is either not installed into the bottom of the reservoir properly or it is broken.
Hope this helps
Feb 12, 2015 | Scotsman DCE33PA1BC 15in Built-in...
My NewAir Portable Ice Maker no longer makes ice. It pumps water up into the resvior but the fan motor never turns on and it does not freeze the water. Why is it acting this way?
is the compressor hot? if so, the fan might be dead. the condenser needs air flow to cool down. if the compressor doesn't even turn on, the starter coil (inside the box on the front of the compressor) may be shot.
Feb 20, 2014 | New Air NewAir AI-100S Portable Ice Maker
I CANNOT GET MY ICE BIN BACK IN PLACE IN ORDER TO MAKE MORE ICE I have a whirlpool side by side with ice/water in the door. the buck will not go back in place either i'm missing something or i'm an idiot.
You prob have to turn the gears in the rear of the fridge. Make sure you can get the bin in the tracks it sits in correctly then check to see if the gears on the auger motor line up properly so it can seat properly into the bin. Lmk if you need more help!
Aug 04, 2013 | Kenmore 57029 Side by Side Refrigerator
Ice maker not making ice and water is not flowing
this could be several items so will go down the list in order... 1st you need to make sure you have a good clean filter or that it has been changed recently... sometimes removed and reinstalled will also help... 2nd do you have 120 volts ac current to the water valve when called for water example" someone pushing the water dispenser handle while you test... if you have 120 volts and no water coming you have a bad water valve... if the dispenser is working but the ice maker is not filling with water they do have dual water valves and one side can actually be bad... before shooting the water valve down though if your getting water to the dispenser but not to ice maker make sure the unit is actually calling for water... on most of these ice makers there is a gear motor on the front part of ice maker there will be a white cover over the front of unit remove it and turn gear motor makes sure it is not broke.. is there frozen water in ice maker if so may be the heater on ice maker is bad... if no water again before shooting down water valve make sure the fill tube coming into ice maker is not froze up...if it is froze up most likely you have a weak water valve and needs to be replaced due to not seating properly.... hope this helps hard to diagnose when not sure what all you have already tested or not...
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice maker doesnt make any ice
check fill tube in back to make sure no frozen ice obstructing water flow... also make sure you have a clean filter on unit or it has been changed recently.... there are normally dual water valves on these models... one will work dispenser and one will work ice maker make sure your getting water to ice maker itself... if you are indeed getting water it just will not dump most likely you have a broken gear motor orthe heater in the ice maker has failed.. get another ice maker ....
Dec 31, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Tube feeding ice maker comes off
Good day,
Common problem. Remove ice maker, and make sure tube fits all the way to the rear and seats properly.
Then reinstall ice maker and telescope front part of file tube until it fits into ice ice maker properly. (retaining clip in place).
For the cost, a new fill tube makes sense. Also.........
If the water valve leaks slightly after shutting off during a fill cycle, a plug of ice will build up inside the the fill tube, pushing it off on the next fill cycle. Requires installing a new water valve.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
ICE MAKER HAS QUIT WORKING
take off the cover to the ice maker. make sure the 2 tabs in the middle of the main gear are in tack and not broken. if one of those tabs is bent or broken, the gear will not make a full rotation. if the gear is fine, check your fill tube in the back of your freezer that goes to the ice maker and make sure it is not frozen. if it is, it will need to be thawed. does your unit have a water filter? if so,it may be plugged and need to be changed. the last thing would be an issue with the water value itself. Joe
Nov 18, 2008 | Refrigerators
Won't make ice
I've tried a home made fix to this problem which is working so far. It's a bit of work, so proceed with caution. The problem at least with mine was the back of the gear/motor assembly box. There is a back side of a gear that projects out of the gear box and into a slot in the ice tray. It seems to be made of cheap plastic that broke from all the twisting of the tray. Mine left a couple of prongs still on the gear from the break, which I was able to JB Weld and shape back into a tight fit with the ice tray slot.
To start, push the black button that projects down, holding the gear box in place while at the same time pulling the gear box towards you. The ice tray will fall at this point.
Now the gear box is just hanging by the power cables. The only way that I found to get the box out was to take out the four screws in the corners of the gear box, (careful, there are loose gears in there that can come out) and pull the motor, and circuit board out by their cables. If you did this without any gears falling out, put the clear plastic cover back on so that they stay in place.
If the gears fell out, like mine did, it's not to difficult to figure out how they go back in.
Now if you have enough of the gear protruding out the back to add the JB Weld to, than do that and shape it to fit the slot of the ice tray. I had to let it dry, then sand it to the right fit. Hope this holds for a while. I couldn't order just the gear, and the motor/gear box is $70.
Once shaped, make sure that the gear is rotated in position to let the "Ice tray full" arm drop down. Then take of the clear cover, put the circuit board and motor back into place, then put the cover back on. Put the rear of the ice tray into the hole in the back of the freezer, the put the motor box back into place the way you removed it sliding the new prong into the ice tray slot and cross your fingers.
Sep 08, 2008 | Samsung RS2578BB Side by Side Refrigerator
Ice Maker Problem
The "ice maker module" is pretty vague. THere's lots of things that work together to make ice. Could be a bad motor, a bad solenoid (electric valve that lets the water in), a broken gear, a loose wire, or just frozen up. If you havent pinpointed the problem, you are probably wasting money buying a new "ice maker module". I'd advise looking for obvious problems (frozen/jammed, no water input, broken looking stuff) and if you dont see anything, call a repairman.
Feb 26, 2007 | KitchenAid KSRS25IL Side by Side...
Kitchen Appliances - Others Logo
118 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
