Question about Kitchen Ranges
Contrl keypad flashes auto and 000 tried to cancel per directions no avail rest breaker to clear as soon as powered up unit flashes same bad control pad?
    Top Expert:
  • Kitchen Ranges Master
  • 79,847 Answers
Yes this is most likely the control pad and the circuit board it attaches to are defective. go here for a replacement part and further advice on the part.
http://www.appliancepartspros.com/partsearch/
Posted on Apr 18, 2009
How can I tun oven on. Timer flashing from 000 to Auto. Can't set clock and no elements will function. Think it is something with the end button but can't remember how to fix it.
Try shutting power off to it for a few minutes, to make it easier just go to your breaker panel and flip off the breaker for the oven, wait a few minutes then flip it back on. Unless there is a button thats stuck down, which isn't very common on these due to the membrane type keypad they use, a power cycle to it should clear out whatever is wrong unless its another problem.
Nov 25, 2015 | Ovens
What does E1 and F2 mean?
The F2 E1 error on Whirlpool-manufactured ranges means that there is a communication error between the touch pad and the control board. One or both parts could be bad or the wiring between them has been damaged or not secured properly. If you press Cancel, does the error return in under a minute? If the range is under warranty, contact the manufacturer.
IF you want to try repairing the unit, first unplug (or trip your circuit breaker to off) your appliance. That will a) reset the error and b) allow you to safely access the control panel from the back of the range. If you are handy and willing to take the time, you can disconnect the wires and watch for continuity as you press various parts of the keypad. (If you don't see any response, try reversing the leads.) Make sure that the wiring harnesses are seated correctly. They can become crooked and not make good contact at either the keypad or the control board. If you get a response from some keys and not others, replace the keypad. If the keypad is working, skip directly to replacing the control board.
If you aren't handy, start with replacing the keypad. Then replace the control board if the problem persists. (Some vendors will allow you to send back a part if it doesn't solve the problem.) Please add a comment with the model of your range for the part numbers and price lists.
I hope this helps.
Aug 16, 2015 | Kitchen Ranges
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Main oven wont work because auto light flashing, how to turn off auto light
Hello, Thank You for using FixYa. I will be helping you today.Without model number its a little harder to figure out but lets give it a try.Did you press cancel or off? If this doesnt work unplug the unit for five minutes and dont cheat five minutes or turn the breaker off. After five minutes if the control still says the same thing chances are you have a stuck or shorted keypad,Which would have to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Ovens
My washer begin washing but the stop and has the code lp what sim to be the problem?
This are the only codes for your washer. hope this help. WHIRLPOOL Calypso Washing Machine Failure Code Condition Check/Repair "PF" Power Failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. "FL" Flood Condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. "Er" Processor Reset Error This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. "LF" Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display. "CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display. "Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. "CA"
"Cl" Average current limit Or
Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "Cl" for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Press STOP/CANCEL to clear the display "ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Press STOP/CANCEL to clear the display. "Sr" Stuck Relay "Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
Press STOP/CANCEL to clear the display. "LS" Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Feb 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Code ce and lf
controller, “CE” flashes and the unit beeps once.
Some common causes of “CE” errors include:
• Conformal coating on serial communications pins between the machine controller
off the pins.
• Check the resistance values between the serial communications pins with the
• Check the quick disconnect at the motor terminal. The drive motor must be hooked
up properly or a “CE” error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
If the water fill time exceeds ten (10) minutes, the water valves are turned off and “LF” is
flashed.
Aug 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 01, 2009 | Kenmore 42822 Front Load Washer
Lights on Washer Machine flash but Washer doesn't work
Mar 31, 2009 | Kenmore Washing Machines
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Locked
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
It may be a failed keypad. If so, the unit cannot be repaired since the key unit is no longer available.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Sharp R-7A85 Microwave Oven
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
