Question about Refrigerators
My GE side by side refrigerator quit working.
I have a GE Model #GSS22KGMD, side by side refrigerator (about 7 years old) that recently stopped working. The water dispensor quit working, then the ice maker stopped, then the top of fridge stopped getting cold. The fan, condenser, compressor were all still working. I cleaned out the fan and let it dry out for a few days (coils in freezer were frozen). After letting it dry out for a couple of days, it started to work again, but then the exact same thing happened again. I thought maybe I did not keep it unplugged long enough for the ice to melt off the coils (they are behind a panel in the freezer, so you can't see them). I am trying again to do the same thing, but someone mentioned that the refrigerant may be low which is causing problem. I work in the automotive industry, and can easily get R134A refrigerant (they actually sell it for vehicles in cans with sealer and refrigerant together for people to fix their vehicle's air conditioners themselves). I just don't see where the adapter is to fill the compressor/condenser?). Anyone with any advice?
  • Anonymous Apr 28, 2009
    I have the exact same problem. How ironic that I have also had mine for 7 years.
  • 98 Answers
The automatic defrost system is not working. All frost-free machines have a heater in the freezer to melt the frost away on a timed schedule. Every day or two the defrost cycle is initiated by the defrost timer. A heater melts the frost, then the cooling system is turned back on.
Posted on Mar 07, 2017
5 Suggested Answers
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
  • 43501 Answers
SOURCE: the refrigerator quit getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Posted on Dec 27, 2010
GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
May 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer stopped making cold over night, its a GE
Try to check for Warranty protection, and if the time coverage has not yet elapsed. If it has not, try to take to service technician, if it has, then the problem is just the Coolant, a chemical liquid that when its volume is expanded, its temperature drastically drops, its called freon. Try see if you can replace the coolant. :)
Apr 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
535 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
