Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
How do reset this unit when the filter light flashes ?
The filter has been replaced but ft keeps flashing on the screen , and it will not cut back on.
You still need to empty the water out of the unit. There are two hoses at the bottom on the back of the unit. Empty both of them and hopefully, the unit will reset and start back up. It worked for me.
Posted on Jun 10, 2009
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
Water filter on aprilaire model 700 light keeps flashing
You need to reset by turning thermostat dial all the way to test reset. It will reset itself, then go back to your setting.
Mar 05, 2014 | Aprilaire 700 120V Power Fan Humidifier...
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
I have a rennai energysaver 556ftr heater, and the filter and on light keeps flashing red, i've taken out the filter and cleaned it, but still the lights are flashing. what's wrong?
If you removed the filter to clean it, while the unit was ON, that may be the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit from wall outlet. Leave unplugged for 15 minutes. Remove and replace the filter. After 15 minutes has elapsed, plug the unit into the wall outlet and turn the Master ON/OFF Switch to ON. The unit should have reset itself and reverted back to the original factory default settings. In which case, you can change the settings to what you desire.
Just remember to always turn the Master ON/OFF Switch to OFF, when removing the filter to clean and replace it.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
Codes flashing on door screen after power blip
You had a power surge due to the storm, unplug the unit for 5 min's and see if it resets the faults.
Jul 09, 2017 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/IQAir-healthpro-plus-owners-manual.pdf
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
GoVacuum
Apr 08, 2010 | IQAir HealthPro Plus Air Purifier
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Mar 22, 2009 | Hunter (30067) Air Purifier
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
813 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
