Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Going wireless hi just installed a new wireless router from AOl that appears to work OK using wired connection ,tried to connect my Belkin wireles adaptor F5D7050 but AOL do not support this have downloaded drivers but a pop up asked for encription no but how do I add this detail ?
Hi, sorry to hear you also having problems with the Belkin. I just bought exactly the same one and have just replaced it with a Netgear one as it didn`t work very well! Dont think the software is too good with Belkin but the encryption I used was TKIP (Belkin did work sometimes!) I also had a network key. sorry I cant help more-melanie
Posted on Sep 18, 2007
SOURCE:
I have a Dell Inspiron 6000 w/ window xp. I show my wireless connection on the signal is excellent but when i click internet explorer its says its connect to internet - i dont have working offline clicked...
Try connecting to another wireless connection... if it connects to another connection and you get to the internet, then it is something with your wireless router or modem. Your PC can "see" a wireless connection, so it is NOT PC hardware.
It sounds like you can connect to the router, but cannot go through the router to get to the internet. Probably a simple issue with your modem or router. Try power cycling the modem, and power cycling the router. Then restart your PC and try connecting again.
If all that fails, try installing Mozilla Firefox and see if that will get out to the internet. It may be a problem with Internet Explorer.
Sep 09, 2009 | Dell Inspiron 6000 Notebook
Hi, we have a Belkin wireless router and the 'world' light has disappeared. We have been in contact with our service provider and all seems to be ok on that side. I understand there is a lifetime warranty...
Hi Nenia, could please give us the model number of the wireless router again from Belkin.
Second , are you trying to connect to the wireless router, using a wire or using the wirless only.
Thanks
Proton
Oct 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin n1 router - wireless light not on - laptop has limited connectivity
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
Oct 05, 2008 | Belkin (F5D7230-4) Router (587009)
Connection
Update the firmware on the router to the latest version available on Belkin's website. Do this over a wired connection, NOT wireless. Also, make sure that your modem is not the issue.
Apr 10, 2008 | Belkin (F5D7230-4) Router (587009)
Need Belkin Disc; same problem with setup
R u connecting through the wired connection or wireless connection ?
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Wireless Connection
Follow trhis posting as I'm working a pretty much the same prolem
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
trying to get a laptop on aol
Hi We are trying to connect to Aol by laptop.... More...
Jeff
Feb 08, 2008 | Computers & Internet
Connecting a new wireless notebook to my existing Belkin 802.11g
All the steps you have mentioned is You are correct..you can connect by configuring the WEP code. but if you have disabled the ssid broadcast then you have to add your access point(FSD7239-4) manually when the wireless discovery fails to detect.
And also refer the manual of the Notebook or wireless adaptor' manual for how to configure the same. (Check the help files of the client configuratin utility if anything installed if not you can refer how to use Wireless Configuration in windows.)
With Regards,
TPV
Jan 30, 2008 | Belkin (F5D7230-4) Router (587009)
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
Problem with belkin router
assuming you are connecting wirelessly; you may have to check that the router is allocating ip addresses automatically to your pc's. connect one of your pc's to the router via the RJ45 network cable that was supplied and not wirelessly and type 192.168.2.1 in your internet browser, this will take you into the routers setup menu. Look for a menu refering to 'DHCP' and make sure that this is enabled, then look for the channel number that the router is using (normally 6 or 11) and make a note as if you are still experiencing signal loss, you can get back into the router and change to any channel between these numbers incase you are getting appliances interfering with the signal, save and exit from the router menu. disconnect the cable then go to control panel, network connections and right click on the connection you are using whether it is wired or wireles and click on properties. Look for the line TCP/IP and again click on the line and select properties, then make sure automatically obtain ip address is selected, ok and close window. Restart the pc's and you should have a connection.
Jul 08, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
100 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
