Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
Poor print quality after numerous head cleaning
I have an epson stylus phote RX620. My print quality is very poor. I've run the head cleaning about 20 times and the nozzle check still has gaps and the printing has lines. I have wasted a lot of ink. The troubleshoot guide on Epson website says it needs to be serviced at a repair center. Do you know of anything that might fix this from home?
    Guru:
  • 523 Answers
Hi Friend,
As per ur issue i will provide u 5solutions kindly try these u will get a permanent solution for this problem is as follows,
1.Banding Issues
Why are there faint horizontal bands in all my prints? When printing photos we need to ensure the printer is set up correctly to achieve the best possible output.
Note:
Some of our models have a paper lever (typically located under the printer lid). This is the paper thickness lever and will allow more room between the print head and the paper. The thickness lever should be in the envelope or plus (+) position for media heavier than 25 lbs. If your product does not have a thickness lever, then the print will automatically adjust.
Output issues can also be resolved by selecting the correct driver settings. To access the printer settings from an application, please follow the steps below:
  1. Within the software you are printing from, click on File and then Print.
  2. Ensure you have the correct media type selected.
  3. Also, set the print quality to at least Photo or Fine.
  4. If it is already set to Photo or Fine, try increasing it to Best Photo.
  5. Try printing your photo again.
2.Repeated Cleaning Cycles Needed Why do I have to run cleaning cycles all the time?
This issue may be caused by leaving your printer on for extended periods of time without using it.
Please note that it is important to always turn your printer off by the power switch (not by a surge protector or power bar) when not in use, as this protects the printheads from exposure to air and dust which can cause blocked nozzles.
Also, we recommend that you use only genuine Epson ink cartridges which have been manufactured by Epson using the most advanced quality processes and inks specifically formulated for your Epson printer. The use of non-Epson ink cartridges or ink refills may cause damage to your printer. These products may also reduce the quality of your printed output.
3.Calculating Lines Per Inch (LPI)
How do I calculate lines per inch (LPI)?
Depending on the resolution, your printer is capable of various lines per inch (LPI). The following is the LPI calculating formula:
dots per inch x .67 = lines per inch
Example:
360 dpi x .67 = 241.2 lpi
720 dpi x .67 = 482.4 lpi
1440 dpi x .67 = 964.8 lpi
The same formula can be used for lines per centimeter.
DPI x .3933 = LPCM
4.Hole-Punched Paper
Hole-punched paper is not a supported paper type.
Kindly try these steps u will get a permanent solution.If u have any clarification kindly note it down i will provide u the instant access
Regards,
Ayyasam
Posted on Jun 01, 2009
Sorry it took so long to respond.
How do you take the printer head off?
Posted on May 28, 2009
    Genius:
  • 1,689 Answers
Hi nacks,
thank you for using fixya.
aside from having it repaired, best bet is to replace the cartridges or if the printer utility has a calibration tool, use that also, aside from just cleaning the nozzle.
if this did not help, get a q-tip, put some ethyl alcohol, do this infront of a fan. swab the nozzle with the q-tip for about 5-8 seconds. once done, shake the cartridge. then run a nozzle cleaning.
these are the DIY when it comes to before-service options.
hope this helps.
regards,
voodoo
Posted on May 04, 2009
I changed black ink cartridge and now pages that are printed are really poor quality and really hard to see...faded in color and sometimes smeared in some spots. Help.
Try going into the menu and cleaning your print heads. If that doesn't work, take out the cartridge and using a cotton swab and alcohol, clean the print heads.
Aug 16, 2011 | Epson Stylus 880 InkJet Color Printer
Poor print quality, not fully black with white lines through text/images.
The white lines are caused by some CLOGGED ink-jets that are not spraying the ink onto the paper at the appropriate time.
Start the Epson printer-software, and run a "print-head-cleaning-cycle", to try to UNCLOG those ink-jets.
Oct 17, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
My print quality is poor. When I run a print check there are gaps in the print so I clean the print head and there are still gaps. I've done this several times.
takeoff print head use wet cloth to clean, repeat until problem solve. If not try soak with warm water just at dirty part only not hole print head, ok
Sep 03, 2009 | Epson Stylus Photo R300 InkJet Printer
Print quality is poor on my Epson DX4000.
It maybe on it's way out ,they don't last forever but try epsoms solutions
https://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX4000-printer/Drivers-Support?target=article&extn=.html&articleId=1358
Jul 29, 2009 | Epson Office Equipment & Supplies
No shadow density in photograph printing
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Jan 13, 2009 | Epson Stylus Photo® RX620 InkJet Printer
Epsom RX620 Poor quality photo prints
I have got round this problem by routing my pictures via Picasa 2. Printing direct is still a problem, but I think I can live with that for now.
Richard
Nov 18, 2008 | Epson RX620 All-In-One InkJet Photo...
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Poor print quality
im sure your familiar doing the head cleaning from the computer / driver at least 3x consecutively
and still the issue persists, hardware problem
printer needs service / this might come handy : http://www.epson.com/loyalty
Jan 03, 2008 | Epson Stylus 680 InkJet Color Printer
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
