Question about Car Audio & Video
Hooking up audio
How would i put a older ford dolby radio system in a 88 cavalier z24 the wire colers dont match any suggestions
    Problem Solver:
  • 11 Answers
Unfortunately, even if you get the wiring sorted out, the Ford radio chassis does not fit in a GM - the mounting is entirely different. The wiring harnesses and colors are also entirely different. Maybe best to find a GM radio - most of the GM radios should fit and plug right in.
Posted on Nov 07, 2009
Car wont start after driving through high water
I would have to say its flooded. I would start by taking the head off and spark plugs out to alow air to the cylenders to dry, drain oil and check for milky residue in oil. put fresh oil back in. good luck..
Dec 07, 2013 | Metra 99-4544 1986-1998 Chevy Cavalier Z24...
I have a 88 Z24 Cavalier that when you start it it will start and die like its not getting fuel. we have checked the injectors the spark plugs and the injector wires everything works perfectly fine bu
on older models we had a procedure as follows.
hook up a remote starter switch turn key to on position and crank.
if there is no attempt to start or fire then the problem is in the electrical wiring. won't run in ignition on but will run in ignition start position.
They used to use fusible links that blew when they got old.
hope this helps.
Feb 01, 2013 | 1988 Chevrolet Cavalier Z24
Need a fuse panel diagram for a 1989 chevy cavalier z24
http://www.v6z24.com/jbodyforum/looking-for-88-z24-fuse-panel-diagram-t108680,highlight,fuse+panel.html
Dec 18, 2010 | 1988 Chevrolet Cavalier Z24
My 88 cavalier z24 starts to run rough as it warms up it is throwing ecm code 43. what is esc and how do you fix low voltage to it
Electronic Spark Control runs a self check and it failed the check. You need to replace the HEI module inside the distributor, check all the wires and connectors for rust and clean as needed.
Aug 28, 2010 | 1988 Chevrolet Cavalier Z24
Wire harness dont know how to hook up radio cause colors dont match up
If your puting in a aftermarket stereo system, they make adapters that will plug into the factory harness and have a diagram of what to hook up to your new stereo. They should have one of these at a stereo store or even auto parts or Wal Mart. I had to put one in my 89 Caravan and 88 Prelude. I got them from the local stereo store and they were about $12 bucks or so. Depends on how much your stereo place overcharges.
Hope this works for you....
Oct 16, 2009 | 2000 Oldsmobile Alero
1989 Z24, 2.8v6 intermittent stalling while driving. Sometimes will restart, but not go far, sometimes will not restart at all. Usually starts fine the next day, may run OK several days before acting up...
the pcm may have a cracked board, i had an 88 cavalier z24 with the same problem, replced the ecu and it ran fine, the problem is that the boards inside the pcm crack and lose connection, the next time it acts up open the glove box and try tapping on the pcm, if the car responds at all, the pcm is bad
Jun 08, 2009 | 1989 Chevrolet Cavalier
I need the factory audio color codes diagram for 1996 z24 chevy cavalier
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck and hope this helps
Apr 20, 2009 | 1998 Chevrolet Cavalier
88 chevy corsica
change the saffty nutrol switch i take it front wheel drive if so right where the tran line up u will see a plug on the tran either 5 or 7 wire some time or or less wire
Jul 29, 2008 | 1988 Chevrolet Cavalier Z24
Fitting car speakers
direct to front s out from sterio have to match up know were your old ones go a wire harness for your car says all labeled nice were to go weird colers in such ok get that match it up to back of head unit wireing it direct ok postive on + negitive on - ok its notto hard if u dont know colers u call deler they tell u the coler codes for your car write it down ok
Jan 22, 2008 | Denon AVR-3805 Receiver
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
