Question about Dryers
Maytag performa dryer turning black inside dryer and turning my clothes dingy. I can wash my clothes and the rinse water will be clear then I can dry my clothes put them back into the washer and the water is dirty!
  • Anonymous Apr 30, 2009
    the whole inside of my dryer is turning black
    same problem
  • 11 Answers
SOURCE: Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
Posted on May 20, 2007
  • 1294 Answers
SOURCE: hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 26, 2008
SOURCE: maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
Posted on Sep 04, 2008
docjohn174
  • 943 Answers
SOURCE: maytag performa dryer pye/g2200
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
Posted on Oct 01, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
Posted on Dec 19, 2008
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My dryer is taking to long to dry clothes and the setting dial moves very slowly if at all.
Make sure the exhaust vent is free and clear. Lint build-up can cause it to take longer to dry clothes. Also, try putting the timer on another setting to see if it makes a difference. If you are using "Auto", try putting the setting on a manual time setting to see if that helps. You may have a bad timer or bad moisture sensors.
Feb 24, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Black film inside
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 08, 2009 | Maytag Performa PAV2200
Discolored dryer drm
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Apr 06, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Leaves clothes very wet and soapy
Your pump is clogged. This stops the machine from spinning out or rinsing. You have to locate the thing, (comes under the tub, lower end of big black tube) take the clamps out to clear the muck. Refit as you have dismantled. First try to drain out the water completely or you will flood your room.
Mar 02, 2009 | Maytag Performa PAV3200
Maytag performa dryer takes a long time to dry clothes on auto
What you have is a obstructed dryer vent. If you remove the vent hose from the unit you will see moisture inside it. This is why your unit isn't drying. If the heater has no air flow the overload is tripped. Check your vent for any blockage most of the problem is at the outside end of your vent. there's a flap or chicken wire you may find the obstruction there. Or you can use a leaf blower connect it to the inside vent, cover the outside vent with pantyhose. ( so you don't get lint allover your yard ) and you can clear your like that way. Good luck hope this helps
Jan 10, 2009 | Maytag PYE2300AY Electric Dryer
The lint is not being washed from machine. All dark clothing has lint residue. How can I rectify this problem please? Currently my husband using damp cloth has to wipe over black clothing extensively prior...
the self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
  • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
  •  no soap.
  • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
the lint filter may be defective since it has always had this problem, but its worth a try.
Jul 01, 2008 | Maytag Washing Machines
Dryers Logo
270 people viewed this question
Top Dryers Experts
