Question about Zenith Z37LZ5D 37 in. LCD TV
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how?
  • 2 more comments
  • rktrade Apr 22, 2009
    I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
    Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
    So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
    Is it good to order PSB?
  • rktrade Apr 23, 2009
    Purchased 2 and half years ago. Expired one year warranty.
    Zohail,
    This is LCD TV.
    There is no problem with the wall socket nor current.
    I put other appliances on same wall socket and worked.
    It has to be internal problem.
    As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
    Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
    Turn off remote control, light turns red.
  • rktrade May 14, 2009
    I fixed the TV.
    Orderd power supply board which cost me $136.51 total.
    Replacing was simple.
    Just removed the rear panel cover then electronic board housing cover.
    Took power supply board with all the connector cables and replaced with new one.
    Problem was a transformer connector which got burned and blow up the plastic cover.
    But no problem with fuse and capacitors.
    Thanks all for advises.
  • 11,896 Answers
The problem is that the sound output capacitor has popped and will need to be replaced by a technician unless you have an ohmmeter and can test each capacitor to find which one is bad and then replace it.
Posted on Apr 24, 2009
  • Nate Stansfield
    Nate Stansfield Apr 24, 2009
    If there is no picture or sound, than the power supply capacitors will need to be replaced.
  • Nate Stansfield
    you may also want to remove rear cover and see if the glass tube fuse is popped or not. If the stip in the middle of the fuse is broken, that means the fuse is bad and you will have to buy another fuse and replace it. I would check this FIRST before any other repair attempts.
    President:
  • 1,223 Answers
Kindly change the socket from where supply is coming it means wall socket where u tv is plugged in , changing power board in ur tv doent solve ur problem , if u buy this expensive part and may be it will not help u
kindly first check the outer environment
Power Plug of ur TV
AC Wall Socket
Voltage rating from the power socket , check if it is low from supply and may be high
pls confirm all to me then we can go forward
Posted on Apr 23, 2009
  • Shoaib Rais
    Shoaib Rais Apr 23, 2009
    Pls also tell me is it LCD or PLASMA bcoz both comes in in this brand Zenith
    Sergeant:
    Champion:
  • 219 Answers
Hi, Well if your TV is under warranty then call the service center and ask them to repair it.Why do it by urself buddy. Thanks! Sandy
    President:
  • 1,263 Answers
If it comes to a replace ment board that is a fair price. matter of fact if you purchase the board over the web rather than a electronics supply shop locally you are wasy ahead of the curve. my advice is however if you have to ask how to replace the board you should not attempt the replacement your self. you should always be safe when working with electronics wether they be plugged in or not. often times even unplugged the unit wil;l still store a charge in it's capacitors. also if not careful static shock can damage other componants in the unit. find a friend to help you or take to a good repair shop.
Posted on Apr 18, 2009
No power! tv made a popping sound,went out and never came back on.
You probably just lost components in your power supply. A repair like this is generally 175-225 dollars.
Jun 06, 2011 | Zenith Z37LZ5D 37 in. LCD TV
Can't auto program Zenith TV for cable channels
  1. Did you try to call LG/Zenith customer support and see if they can help you? If not find your nearest LG/Zenith service center (not Best Buy) preferably a small service shop to see if they have a service remote to unlock it
Aug 23, 2009 | Zenith Z37LZ5D 37 in. LCD TV
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
Pop then dark
Oh my..... I never heard anything but praise and value spoken about my TV! IT JUST WENT POP!!!!!! Video is completely gone - it's off warranty. What now a giant doorstop?????
Jan 28, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Would like a guru's assistance
They need to replace both sustain boards along with the power supply and the logic board. These are the common 4 for a LG/Zenith dead plasma that popped! Good luck.
Dec 06, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
After 20 months old and now dead
I purchased this tv 2/06 and it went POP in 04/07. Less than 60 days after my warranty expired. Went back and forth with Zenith for several months. I refused to take NO for an answer. Customer service stinks and you have to be very persistent. They eventually agreed to fix it. Repairs cost over $2000 and I have my tv back. Next time it breaks just going to throw it out. Zenith sucks.
May 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Green light blinking- no picture
This just happened to my Z50 yesterday...10 days after it came back from the repair shop! The first repair was for the "popping" problem where the tv makes a loud pop and the screen goes black. This took 6 weeks to get fixed. For this new problem the repair center is getting hold of LG to find out what to do. I am also calling them because I see this is a major problem that people have been experiencing out of warranty. The first customer service rep told me I was out of luck but I am not accepting that answer. Good luck, we'll both need it.
Feb 05, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith Z37LZ5D 37 in. LCD TV Logo
146 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
