Question about Canon imageRUNNER 6000 Copier
Error code e542
Copier will not work.Says to turn off machine and gives erroro code of e542
  • sunvalleymgr Apr 19, 2009
    That was the easiest repair I ever made. A table was in the way.it had been there a week, but we haad not colated any documents until yesterday. Thanks!
  • Canon Expert
  • 1,326 Answers
The error code means that the finisher bins could not find HP. The problem shows up when something is placed under the bins and stops them from moving down, most of the time a "G" file or a case of paper. Move the object and move the bottom bin up till you hear it click. Before doing that make sure the MAIN Power Switch is OFF on the right side of copier... Then turn the copier back ON and it should clear it self.. Good Luck
Posted on Apr 19, 2009
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
ERROR CODE E-5 HELP RICOH 4522
If you press the "." key you will get the last 2 digits to complete the error message. For example: "E542".
Whatever the result, 'E5xx' is always related to a fuser error; That means, you have a blown fuse, lamp, or thermistor, and the problem, and the service code can only be reset by a technician in service mode after the fault is fixed.
Nov 25, 2011 | Ricoh Aficio 450 Copier
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
I am getting a sud erroro code
This usually means that you have used an excess of detergent. Front loaders use less detergent as well as less water. Try running the machine without detergent to remove the over supply of detergent in the machine. You may have to physically remove the excess by hand at first. Hope this helps!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When I try to turn the camera on, the lens will not go all the way in or all the way out and it' a bit cockeye and I get an error code for a quick second but the erroro code doesn'tstay on long enough
when the lens can't trace or retrace it is impossible the get a save system reset.
Probably your lensunit is stuck.
If Kodak can't give you an proforma invoice Rotronica in the Netherlands can fix it for you.
regards,
Rob NL
Apr 30, 2009 | Kodak Easyshare M753 Digital Camera
Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Apr 23, 2009 | Canon imageRUNNER 6000 Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Konica c6500 error code c-2451
What error code.
Toner sensor's are usually at the far end of the Toner Cartridge. It will have what looks like a connection, silver or bronze wire, or a chip look thing, if it is dirty it can cause error codes as it is not making contact with in the machine.
Oct 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Canon imageRUNNER 6000 Copier Logo
882 people viewed this question
old marine
old marine
