Question about Rollei Prego DP5300 Digital Camera
Memory card cannot be used
I formatted memory stick using my nikon coolpix s9 camera and now there is a dialogue 'this memory card cannot be used'. Pl help me out. Thanx bright
  • 3 Answers
Follow these steps: 1. If you have a SD card reader, insert the SD card and look for it in Windows Explorer. In this case, mine was labeled F: 2. Right Click on the drive for the Card Reader (IMPORTANT) and choose FORMAT. 3. Format card with default settings. 4. Turn Camera on and go to MENU> FORMAT CARD 5. Before answering the next question, insert SD card into camera. You will hear it beep twice. 6. Choose FORMAT and the card should be formatted for use on the camera. Cheers!
Posted on Sep 19, 2007
SOURCE:
How do i delete all pictures off my camera
  1. Press the play button--which features a picture of a solid triangle in the middle of a rectangle--on the backside of the camera.
  2. Press the "menu" button to access the playback menu.
  3. Rotate the multi-selector dial to scroll the menu cursor to the "delete" option represented by a trash can.
  4. Scroll to the option "erase all images" and press the "OK" button on the backside of the camera.
  5. Scroll to the "yes" option on the confirmation dialogue and press the "OK" button on the backside of the camera. If a removable SD memory card is inside the camera, the camera will delete all of the photos on the card. If there is no SD memory card, the camera will delete all photographs in the internal memory.
If you need more help concerning your Nikon COOLPIX camera, I've posted an online manual of your camera below.
http://www.nikonusa.com/pdf/manuals/coolpix/S200_en.pdf
May 07, 2011 | Nikon COOLPIX S200 Digital Camera
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
My coolpix s9 cam will not transfer pics from cam..i would use a card reader but the pics are on the cams harddrive and not the sd card...please help!or does anyone know how to tranfer pics from cams...
You can copy pictures from the internal memory to a memory card by selecting "Copy" from the Playback menu.
Press the MENU button to bring up the main menu, then select the right-pointing triangle to get into the Playback menu.
Jun 28, 2010 | Nikon COOLPIX S9 Digital Camera
Nikon Coolpix s9
Do you really want to download your pictures this way? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. You can also use software such as Nikon Transfer and Nikon ViewNX to transfer and organize your pictures. You can get the current versions of Nikon software from http://support.nikontech.com/app/answers/detail/a_id/61
Apr 12, 2010 | Nikon COOLPIX S9 Digital Camera
Transfer images from internal memory to sd card on nikon coolpix s9
Press the MENU button. Select Playback (right-pointing triangle). Use up/down to select "Copy".
Nov 18, 2009 | Nikon COOLPIX S9 Digital Camera
There are 60 pictures in the internal memory that I can't delete.
Remove the memory card...go into the menu and scroll to "format"...follow the on-screen instructions.
Oct 21, 2009 | Nikon COOLPIX S9 Digital Camera
8GB Memory Card Problems on a Nikon S9
Try to format the card in your camera. Then it should work fine. Otherwise you may need a different card.
Aug 04, 2009 | Cameras
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
I have formatted my memory card in computer now when inserted in the nikon coolpix s9 camera it is showing this card cannot be used
Just use the inbuilt feature on the camera to format the card and it should be usable again (considering the card has not been damaged / corrupted beyond repair)
Dec 29, 2008 | Nikon Coolpix L11 Digital Camera
Rollei Prego DP5300 Digital Camera Logo
770 people viewed this question
Top Rollei Cameras Experts
Jeff
Jeff
TJBeckwith
Level 1 Expert
james laughton
james laughton
Are you a Rollei Camera Expert? Answer questions, earn points and help others
