HP Photosmart C 7280 paper feed problem
When printing I get a ''Out of paper, load tray'' message. There are 20 sheets in the paper tray. I take them out and install again in tray and it prints once or twice. Then I get the same message again and go through the paper loading procedure and it works one more time. Any ideas? TIA.
Terry D
  • lftaileron Apr 18, 2009
    Thanks Richard, I'll try cleaning the rollers.
    Terry
  • 385 Answers
check the feed tray is good, if so.
Clean the feed rollers,
Lint free cloth, distilled water.
Should be good.
Regards
Richard.
Posted on Apr 18, 2009
Also, the paper duplicator?..I, can't remember what you call it, but when you have a paper jam you have to take it off at the back and then put it back on again. Well, if it isn't put back on properly, you will continue to get the "Out of Paper, load tray" message.
Alice
Posted on Jan 12, 2010
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
When I try to copy or print I get a "Out of paper"--"Load paper in main tray"-- The main tray is always loaded with at least 24 sheets of 8.5 x 11 sheets of printer paper. What can I do? Thank you
Kindly reset the product.
Turn the printer OFF remove the power cord.
Wait 30 sec and plug the cord
Turn the printer ON
Remove all the papers before doing the above changes
See to it that you feed upto 10 or 25 sheets and not more.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next section.
Jan 30, 2010 | HP Photosmart 3310 Printer
The printer does not print. It feeds paper and
Visit HP support for this problem (XP):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01853840&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443024
If you have Vista, change query to read "Printer prints blank sheets of paper" > Choose Vista instead of XP
Dec 05, 2009 | HP Photosmart 8250 InkJet Printer
My D7460 will not feed paper The screen says load paper face down in main tray.
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Oct 28, 2009 | HP Photosmart D7460 Printer
Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Jan 04, 2009 | HP Photosmart C6280 Printer
Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Sep 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Sep 27, 2008 | HP Photosmart 8450 InkJet Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Can't print onto 4x6 photo paper
Did you try this from HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748340&lc=en&cc=us&dlc=en&product=1155996&rule=45149&lang=en
I also suggest you remove the back door & clean the wheels with a clean no lint water dampend rag. Replace the door.
Jan 26, 2008 | HP Photosmart D5160 InkJet Printer
256 people viewed this question
jasbo
jasbo
