Question about Thermador DWU244 Dishwasher
White film on glasses after a run.
The Thermador dishwasher leaves a white film on all the dishes and glasses, especially the glasses. I have switched from powder dishwasher detergent to liquid detergent and that did not help. Some times the liquid detergent is just in a pool at the bottom of the machine after a run.
  • Edster1 Apr 27, 2009
    I have the exact same problem with a white film.
    President:
  • 1,197 Answers
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
Milky residue on dishes, especially glasses
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 28, 2011 | Bosch Dishwashers
My thermador dishwasher leaves a white film on the dishes, as if scorched, or a soap film?
heatman101
Mar 20, 2011 | Thermador Dishwashers
Leaving white residue on glasses and dishes
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Dec 24, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
The dishwasher is not cleaning well. There is a film left on the dishes and especially the glasses.
heatman101
Nov 30, 2010 | Kenmore 24 in. 16039 Built-in Dishwasher
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Please post back if more information is required.
Daniel
Aug 07, 2010 | Dishwashers
Making noise and leaving white film on dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
the white film is due to hard water. go to www.dishwasherfilter.com and get the new difi filter. it will solve your problem imediately and extend the life of your dishwasher. the product is amazing and guaranteed to work. very affordable
Mar 29, 2010 | GE Nautilus 24" Built-in Dishwasher
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
Dishwasher is leaving white film on dishes. I have handwashed and when I dry the dishes the film is back. Please help I want to scream. Do I need to buy new dishwasher?????
just relax all you need to do is run a few load with tang brakfast drink run fauset till you get hot water put about a cup in the bottom and fill soap cup with tang you may run dishes with the tang NO SILVER JUST PLATETS AND GLASSES
Jun 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
White film 0n dishes and especially glasses
It is a drain problem, check the drain hose and drain pump.There should be some problem with the drain being blocked that is eventually pushing the dirt water back and front.Thereby leaving detergent and dirt back in the dishwasher.
Provide me the model number and i can help you out with some internal diagrams in case you don't find the drain pump.
Good luck and please do post for further doubts arising on this solution.
Jan 20, 2009 | Dishwashers
Thermador DWU244 Dishwasher Logo
410 people viewed this question
Top Thermador Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Jude24
Francois Havenga
Francois Havenga
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
