Question about Milwaukee 0612-20 14.4v Cordless Drill Kit W/ Worklight
How to unlock the chuck
I have a Milwaukee power plus drill 12 v rpm 0-1100. the numbers on bottom are 1124 and 0501-9. There is no chuck key insert. The chuck has a direction arrow for both open and close but if you turn it to open it just spins and I can't get the drill out. How do you do it
    Novelist:
  • 108 Answers
Most of them you just hold the chuck tightly, and turn on the drill in reverse.
Posted on Apr 19, 2009
Milwaukee1/2 magnum hammer drill keyless chuck stuck closed
yes call 1-800-sawdust that's the Milwaukee factory number. They can tell you what the spindle and thread sizes are so you can order a keyed chuck. They should even be able to tell you what chuck they have that will fit it.
Jan 12, 2013 | Drills
Lost of power
Pull the brushes out - remove 3 screws holding gearcase to handle & remove gearcase with armature from handle.
More than likely you will find the field inside the handle is melted down & binding the armature up. Depending on how long it ran smoking you may have cooked the armature as well.
Jan 05, 2012 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
I want to know the steps needed to replace a 1/2" keyed chuck.on a Milwaukee 0234-6 Magnum Drill
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
Jul 31, 2011 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
Won't turn on with the trigger
Check the position of the forward/reverse switch. If it in between settings, it will not operate.
--W/D--
Jan 21, 2011 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
Chuck is stuck open cant get to free how do i replace chuck
You need to secure the drill - perhaps in a vise - and insert the chuck key (if it is a key-less chuck you may have to use a pipe wrench or something similiar) and give the key (or wrench) a sharp hit to release it. The chucks are screwed onto the drill with a right hand thread. Let me know if this works for you. Thanks
Jan 02, 2011 | Milwaukee 0200 20 Drill 3/8 1200 Magnum
How do I change a bit
This drill uses a keyless chuck. which means you have to hold onto the barrel by the end of the drill chuck. Then you need to put the drill in reverse to open the chuck to put a bit in. Insert a bit and then put the drill back into forward and hold chuck to tighten.
Nov 14, 2010 | Milwaukee Tool Milwaukee 0824 24 v18...
Chuck is very hard to adjust
Try lubrication, and check that the retaining screw, down inside, has not come loose. failing all of that, replace the chuck.
Oct 02, 2010 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
May 30, 2009 | Milwaukee 0612-20 14.4v Cordless Drill Kit...
Milwaukee 0612-20 14.4v Cordless Drill Kit W/ Worklight Logo
769 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
