Question about Samsung Televison & Video
I am unable to figure out how to remove SAP from 2 of my stations when I run the VCR through the Zenith TV. This is a relatively new problem. All the other channels I record are okay. I downloaded instructions as "how" to do this but did not work. Now my "menu & info" screens are black. Also when it is just on a TV station the sound is fine.
  • vlo Apr 19, 2009
    Rylee, Did you receive the first posting from today? If NOT I will resend.
  • vlo Apr 19, 2009
    I will resend, obviously I deleted it before submitting.
    As I said in the above (first message) my menus and info screens come up black--cannot get to the audio portion or any other information on the menu screens. When I checked today almost any station that says "sap" at the top, there is NOT sound going through the TV. The DVD/VCR is a Samsung, and it says V4800. The TV is a Zenith, no number, just says Space Command. Awhile back I did have another problem that seems to be solved or okay. Certain TV stations would be in Spanish if I recorded them on a video tape (not DVD). I also in the past did see in the Menu/Info area (when it was NOT black as it is now) a listing for Language, it is set on English. Also because of the black screen, I cannot access Audio. I just watched another tape I had and all of the programs were okay, even if recorded on a "sap" station. Also I cannot find any of the manuals for the two sets.
  • 11,896 Answers
LEAVE TV UNPLUGGED OVERNIGHT TO RESET ITSELF. IT SHOULD BE BACK TO NORMAL AFTER POWER DRAINS FROM POWER SUPPLY. THAN GO INTO YOUR MENU SETTINGS AND TURN SAP OFF
Posted on Apr 20, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Please check the SAP settings in the properties of your TV menu and see if a particular language is checked or not. Also try recording these channels again after modifying the SAP settings.
Please tell me the make and model number of your TV (Zenith TV or Samsung TV). Also tell me the make and model # of the VCR.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 19, 2009
  • Rylee Smith
    Rylee Smith Apr 19, 2009
    Hi
    I can only see the single post by you. Please tell me the make and model number of your TV (Zenith TV or Samsung TV). Also tell me the make and model # of the VCR.
    Thanks
    Rylee
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Unable to get stations 17 and 45(UHF)on Zenith model SM2067BT
the problem is station 17 1nd 45 is not yet programmed to your tv...
Sep 11, 2008 | Zenith Televison & Video
Stero SAP
Go to tv setup in the tv menu and turn off the SAP.
Sep 02, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
VCR Help
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Nov 20, 2007 | Sansui VHF6010 VHS VCR
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
Televison & Video Logo
527 people viewed this question
Henry  Thomas
Henry Thomas
