The dvd player doesn't play the dvd's
The dvd player takes a long time to load the dvd and then when it is done, i press play, but it just says ''seq. play'' and nothing happens.
When i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Posted on Apr 18, 2009
What does this stand for it comes coming up when I push the DVD menus button ( SEQ Play)
Hi Beverly it sounds like the DVD player is asking if you'd like the discs in the changer to play the next one automatically, and there should be a shuffle alternative, or a play1 then stop choice as well.
Jan 11, 2015 | Televison & Video
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
My dvd player loads but "seq play" appears. What does this mean?
You should go to the mfr's website and download the manual if you don't have one. The abbreviation 'seq' is normally for 'sequential' which is something desirable if true. It would mean that you could play a series of DVDs.
Feb 27, 2011 | Televison & Video
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
How do I auto set up for my zoooos controller
Auto Setup automatically searches for the right code for your DVD player. For the most popular DVD player models, Auto-Setup takes a few minutes or less, however, less-common models can take much longer or this method may not work at all.
  1. Find the Auto-Setup instruction page in the on-screen Setup Guide. Your DVD player must be on the Auto-Setup instructions for this method to work properly.
  1. Engage Auto-Setup mode: Hold down the Red button until the setup light turns off. Continue holding the Red button and press the Yellow button three times, then release both buttons. If you’ve done this correctly the light will turn back on and remain on until setup mode is exited. When the setup light remains on, the controller is in setup mode.
  1. Wait for a message from your DVD player. Even though you can’t see anything happening, the controller is actually loading and testing various codes. When the right code is found, your DVD player will tell you to press the Home button. If your player doesn’t respond within about 10 Minutes or the time on the estimate chart, press the Home button to exit this method, and use the Direct Entry method instead.
  1. When the DVD player instructs you to press the Home button, be sure to do so before the onscreen timer runs out. If you miss pressing the Home button before the timer runs out, go ahead and wait until a message from the DVD tells you what to do. If you have not yet pressed the Home button, the DVD will instruct you to press the Back button to back up to the code you missed.
Jan 09, 2010 | Fun Rise Zoooos DVD System
Pioneer DV 310 K region free
Step 1) Download the pioneer firmware here http://www.pioneerfaq.info/index.php?question=Firmwares
The site says the firmware only works on region 2 players. For this model it worked for my region 4 player in Australia
Step 2) Burn this file to a CD-ROM with name PIONEER as per these instructions - http://www.pioneerfaq.info/english/burn_guide.php
Step 3) Load the CD and your DVD player with ask you to flash the firmware. It says press play to start but instead HOLD DOWN ENTER during the entire process. DO NOT switch off your DVD during this time. When the tray opens take the CD ROM out but keep the DVD on. The flashing can take up two to three minutes. During this time HOLD DOWN ENTER ON THE REMOTE. The entire time!
Step 4) The DVD player will reboot. The tray should be empty. It will then load the tray back into the player. If the signal is disorted switch on and off.
Your done! Should work.
The most complex way of region freeing a DVD I have ever endured! :)
Jul 19, 2009 | Pioneer DV-310 DVD Player
I have tried playing various dvd's in this machine sometimes i get sound sometimes i do not. Do not get a picture. When I press the play button it saysd "seq play" and then a few seconds later says "stop"....
You can call Zenith customer service and give them the model number of the DVD player and tell them the problem you are having with intermittent operation of the player. They will be able to help you get service for the problem.. I hope this information helps you with your problem
Apr 29, 2009 | Zenith DVP615 Portable DVD Player
Rca dvd player
Hi my name is Justin i have some problem with my rca dvd player when it's started it asked an unlock code so i want you to help me
Dec 06, 2007 | RCA Televison & Video
Televison & Video Logo
487 people viewed this question
Top Televison & Video Experts
