Question about Palm TX Handheld
Every time I click on the desk top Palm application I get an error message that says Palm is experiencing a problem and needs to shut down. This is for Palm TX handheld and I am using windows XP.
  • 689 Answers
Probably one or more essential files corrupted or having conflict. Reinstalling Desktop application will resolve the issue. You can get newer version at http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Posted on Aug 24, 2009
On my window update i get error code 663
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
The 633 error is a connection problem that appears every time you try to use the modem on your computer.
It states "modem is already in use" and prevents you from accessing the Internet.
This problem mostly appears when a device with incompatible drivers has conflicts with the modem driver on your computer system.
The major software that causes this error is the Palm Pilot Software.
With some simple troubleshooting steps, resolve this modem communication error.
Shut down all currently running applications and restart your computer.
Press "F8" repeatedly before Windows begins to open the Windows Advanced Options Menu.
Scroll down and select "Safe Mode." Press "Enter" to log into Windows Safe Mode.
Safe Mode is used for troubleshooting and repairing system components.
Click the Windows "Start" button and select the "Control Panel."
Double-click "Add or Remove Programs" to open the programs window.
Click "Program and Features" (Windows Vista users) and select "Uninstall a Program" to open the programs window.
Click the incompatible software (e.g., Palm Desktop and Synchronization Software) and select "Change/Remove."
Click "Yes" to confirm and uninstall the program from your computer.
Restart your computer normally to complete the process.
Hope this helps
Nov 13, 2012 | HP Pavilion A6400f Desktop PC, Refurbished
Delete page superimposed on my desk top home page
I'm assuming this is a Finder window. In Finder, press Apple-option-W just before you shut down the computer. This will close all Finder windows; they will should not open when you start up the computer unless they were open when you shut it down.
If it's not a Finder window, you will have to deal with whatever application is being told to run at startup. Without knowing what it is, I don't have enough information to tell you more, other than to suggest you go to your User Accounts in System Preferences, click the Login Items tab and either check the Hide box for that application, or remove it from the Login Items list.
May 31, 2012 | Computers & Internet
Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Mar 21, 2009 | Palm Tungsten T3 Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Mio digi walker 220
application MioUtility,exe has performed an illegal operation and will be shut down. if the problem persists, contact the program vendor
program:MioUtility,exe
Exception:0xC000000D
Address:8C06DF8C
Mar 20, 2008 | GPS
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Error Messages
1. There must be some software problem,go and get it checked by the nearby service center.
2. It may also occur due to over loading of data so delete some data first and then try again.
Jan 31, 2008 | Palm Tungsten E2 Handheld
HOW DO I FIX THESE ERROR MESSAGES?
you need to run a inbox repair tool.
Make sure you close outlook
Start > My computer > Tools > Folder options > General tab click on show hidden files and folders > Apply ok
Go to the follow wing location to find scanpst.exe
if you are using Outlook 2007
C:\Program Files\Microsoft Office\Office12
If you using Outlook 2003
C:\Program Files\Microsoft Office\Office11
Double click on SCANPST.EXE
Click on browse go to following locaiton where your pst file as been save
C:\Documents and Settings\Robyn M. Drothler\Local Settings\Application Data\Microsoft\Outlook\outlook.pst
Click on start > then click on repair
Sep 11, 2005 | Palm Treo 600 Handheld
Palm TX Handheld Logo
82 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
