Question about Kenmore 63792 Microwave Oven
The inside oven light in my kenmore elite microwave convection oven just blew How do I repair it. the model is 363.63673201
  • 4 more comments
  • mj1120 Apr 19, 2009
    My microwave/convection oven is mounted under my cabinet...I need to know how to get access to the bulb,,,do I need an electrician or an appliance repair person.....The cost of the bulb in unimportant I just want to fix the problem
    Is this a bulb or fuse issue.....And if so where are they located
    Looking at my oven, the left side is the door hinge. So obviously it must behind the control panel which is on the right side of the oven as you look at it.. Once the control panel is taken off, is it easy to find....I'm just not sure if I need an electrician or an appliance repair person. Once the control is taken off is it easy to see
    Not clear, what needs to be removed on the oven to replace the bulb...will someone need to take the oven off from the cabinet
    What needs to be done to repair the inside oven light of a kenmore elite microwave convection oven. model 363 63673201
    Yes, thank you
  • Kenmore Master
  • 19,396 Answers
I report a solution from MicrowaveSvc , you can contact them to get support and spare parts:
I quote:"Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
You can find them here: http://www.geappliances.com/service_and_support/literature/
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
That should tell you where the lamps are located."
Posted on Apr 19, 2009
  • 916 Answers
Remove the casing to access the lamp. This is a way all counter-top microwaves made and it's done for consumers protection. I would recommend to remove the old lamp and take it to any hardware or electronic supply store to match it up. Though on this model microwave the bulb itself can be up to about $60 for a replacement. It may be more cost effective to buy a cheap replacement then to replace a $60 bulb.
Thank you for using FixYa! Please Rate!
  • 2 more comments
  • machadojr_fe Apr 19, 2009
    In short yes you will need an appliance repair technician. As you need special tools to remove the cover of the microwave. The repair should not be very expensive as the work should not take very long. But unless you have experience with this type of appliance it is highly unrecommended to do it yourself.
    Well this is a bulb issue if the microwave is still getting power but no light. The bulb can easily be found once the casing of the microwave is removed. It will be the only lamp inside and I believe on your model it is on the left when looking at the front of the machine.
    I apologize you have to remove the protective casing this is the top and bottom part of the microwave. The control panel does not need to be removed at all. Since yours is mounted below a cabinet it is most likely going to be removed from underneath. As for the light it will look about the same as the end of a flashlight when you remove the top.
    Yes they will probably have to remove it from the cabinet in order to take off the protective cover. On some ken mores the cover comes off from the top, some it comes off from the bottom, and others slide out through the back. No matter which way it comes off you are going to need special tools to remove it. An appliance repair technician will have these tools with them as they have to do this quite often.
Kenmore elite model 721.80822500 convection oven won't heat. Microwave and other functions fine
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
May 06, 2016 | Kenmore Microwave Ovens
Kenmore elite microwave/convection oven just lost power and will not come back on. have checked the the outlet and it works.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 26, 2010 | Kenmore Microwave Ovens
Kenmore elite countertop microwave/convection oven
Time for a new cover plate or a new microwave. Depending on the age of the unit, the part may not be available anymore.
Jul 06, 2017 | Kenmore Microwave Ovens
Kenmore Elite micro/convect model 64289. Convect not heating...F1 error
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 18, 2010 | Kenmore 63672 Convection/Microwave Oven
Display needs to be replaced on a kenmore elite microwave
Try managemyhome.com. I have a Kenmore Elite convection microwave and found the manual.
Jul 03, 2009 | Sharp R-1750 Microwave Oven
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
Where can I find an owners manual for a Kenmore convection microwave oven online? Model # 87002
Apr 18, 2009 | Kenmore Microwave Ovens
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
My microwave is sweating
No. This is usually a sign of poor venting or air flow. It's possible that the coling fan is not circulating the air properly due to a problem with it or maybe the air vents are blocked. Also, there needs to be a couple of inches around a countertop model on all sides - especially the back - to ensure air flow. Look for buildup on the back vent grille. You can listen for the fan to be running and feel the air flow while it's running. If it's weak or not there, it needs inspection / service. A lack of air flow can cause the magnetron to overheat and be damaged. If this is a built-in model also check your air filter, air duct work and outdoor vent flap. Write back if you still have trouble.
Mar 12, 2007 | Kenmore 64282 Convection/Microwave Oven
Kenmore 63792 Microwave Oven Logo
244 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
