Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Freezes both my desktop and laptop and doesn't let me get to my work on it.
It just freezes both of my computers up. I've got a lot of very important work on this and can't delete it or reformat it. Literally hundreds of hours of work. I did delete some stuff off of it yesterday i did not think I needed anymore. Is it possible I deleted something that gives me access and I need to reload that? Please help! Taylorsmom
    Brigadier General:
  • 6,966 Answers
Hi, Let see if I got your posting/description right: 1. Whenever you connect/access your Maxtor OneTouch External in either the desktop or laptop, the PC will freeze/hang; and 2. The Maxtor OneTouch External contains important files/data that you'd rather not delete, hence you cannot format it likewise. Your query "Is it possible I deleted something that gives me access and I need to reload that?" - No, I don't think so. From what can be assumed from your post, "I did delete some stuff off..." thereafter, you started having problem with the drive, the probable problem is when you deleted some of your files, the Maxtor OneTouch External has not finished updating what was deleted in its master file listing when it was disconnected, powered down or a power surge or even a slight glitch. The result is the File Allocation Table got messed up. This is like the Table of Contents of a book. The pages/contents are still there but since the Table of Contents is either missing or damaged, the PC would not not what chapter is in what page. Thereafter whenever you connect it to a PC, the PC spends considerable length of time looking for the File Allocation Table, what files to what area of the Maxtor OneTouch External and eventually uses most if not all of its resources just trying to know which and where. If it is still under warranty, claim for a replacement and demand that your files be recovered and transferred to your replacement/new HD. If no longer under warranty or your files will not be recovered for you, you have to google for a freeware file recovery utility/software. The objective is for the utility program to access your external HD and copy the files inside to another HD that can accommodate your file size. it has to be another 120Gb or higher. It is possible that you have to run your PC/Laptop in Safe Mode if it will not run in Normal Mode with the external HD attached. You may want to refer to this link of a similar concern (http://www.fixya.com/support/t191153-device_recognized). You can also check if the external is spinning inside by touching the enclosure. Hope this be of some help/idea. Pls post backhow things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 18, 2007
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Maxtor Onetouch III Mini freezes my computers and won't let me access my work.
Hi again, It seems you posted twice, pls here is the link to your other post > (http://www.fixya.com/support/t202613-freezes_both_desktop_laptop_doesnt_let).
Reset dell wireless mouse
A lot of times, when I'm working on a computer, and the mouse freezes a lot, there is malware on the machine. I would download and run Malwarebytes and Superantispyware and let them quarantine anything they find.
Jul 15, 2014 | Dell Computers & Internet
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
Windows XP freezes half way through Restore program?
Select an earler restore point. If it still doesn't work step back earlier. Somewhere in the restore date history there has to have been a date where the system worked. Remember that the restore process can take some time if a lot of material has to be restored
Oct 26, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Freezing
A computer/notebook/laptop can freeze due to a lot of reasons. Here are few noteworthy ones. Check them and see if they help, if not then post a little detail of when it freezes more etc:
a) Antivirus programs have a great tendency of eating up memory quite quickly. So, get a lightweight antivirus program like Microsoft Security Essentials or Avast etc.
b) If you have a low RAM then it is recommended that you run very few applications at the background. Avoid running any unnecessary applications.
c) If you have a desktop set with lots of transitions and effects it can cause huge RAM and often results in freezing of system.
d) Your O/S could be a problem too. If the above things doesn't help try resetting/re-installing the O/S and hopefully it shall help you a lot.
e) Check your system for any viral activities. You can perform an online scan using many free online scanners like Trend Micro etc.
Oct 24, 2012 | Acer Aspire 3620 Laptop/notebook
Compaq Presario v2000 freezes
If your laptop freezes randomly follow the steps given below:
  • Disable Unnecessary Services
  • Run Disk Checkup
  • Disable Startup Programs
  • Clean Registry Errors
You can also get more help from this article:
http://www.backspacetab.com/laptop-freezes-randomly-tips-to-fix-this-problem-for-good/
Dec 08, 2011 | HP Compaq Presario V2000 Notebook
Windows vista freezes
put all your music videos and pictures and other important files on a external hard drive and reinstall vista it happened to me a couple of times its just the computer video card or the ram in the computer is not enough?
Feb 06, 2009 | Computers & Internet
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
111 people viewed this question
Top Maxtor Computers & Internet Experts
Phil Whisenant
Phil Whisenant
Alun Cox
Norman Al-Anbar
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
