Question about Refrigerators
All of a sudden stopped getting cold in the fridge portion, freezer is fine
Hi I have a 4 year old Samsung RB1855sl that all of a sudden stopped getting cold in the fridge portion, freezer is fine
  • 3 Answers
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Posted on Apr 18, 2009
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
I have a two year old samsung side by side refrigerator RSA 1DHMH. The freezer department has suddenly stopped producing ice and the temperature has risen significantly that food as now thawed. I have...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Samsung RS2534 Side by Side Refrigerator
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
REFRIGERATOR SIDE NOT GETTING THAT COLD
they are junk so many problems with mine . when down 4 times
just 2 years old.
Sep 30, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Refrigerators Logo
821 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
